Walk In Freezer - Nothing Comes On - Need Help - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-23-2013, 10:50 AM   #16
Bill Kearney
Rewards Points: 1,174
And meanwhile you're, what, a week without the freezer? Is there really savings to be had here? If this were just my freezer at home I'd be inclined to figure it out. But if my work depended upon it (and the health of my customers) I can't see dragging it out for days just to avoid paying a pro to 'just fix it'.
I second the fuse wearing out note. Like anything else they can fail over time. Always be prepared to replace them, twice. Once to figure out that it actually WAS something else, and the second time after you fix the actually broken parts. The money you'd spend on buying several extras is likely a lot less than the time wasted running back/forth to get more...
wkearney99 is offline   Reply With Quote
Old 03-23-2013, 09:58 PM   #17
Rewards Points: 610
I'm guessin' he has more than one freezer.
techpappy is offline   Reply With Quote
Old 03-25-2013, 02:31 AM   #18
I do have more than one freezer. It was the fuse. I feel dumb for not pulling them out and checking them first but I figured since I had voltage on both ends of the fuse, they were good and the problem was elsewhere. I REALLY appreciate this site and those of you that helped constructively. With restaurants these days, I have to try and save money whenever possible.
smstucson is offline   Reply With Quote
Old 03-28-2013, 04:26 PM   #19
If you had voltage at both end of the fuse
Then your fuse should be good.
ryandeen is offline   Reply With Quote
Old 03-28-2013, 05:26 PM   #20
Rewards Points: 1,214
Read post #18 again he fixed it.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 03-28-2013, 05:43 PM   #21
Roofmaster
Rewards Points: 2,172
So, to measure 220, you simply place the black probe on one feed, and the red probe on the other feed of the double pole breaker?
Thanks to all of you.
Old 03-29-2013, 10:46 AM   #22
Yes that's correct. But always remember, just because your meter reads zero doesn't meant it isn't hot.
JScotty is offline   Reply With Quote
Old 03-29-2013, 07:46 PM   #23
Rewards Points: 610
ryandeen..just to clarify..I said that if you checked with a meter from one end of the fuse to the other end of the same fuse you should get zero volts and that means the fuse is good..if you get 120 volts then the fuse has blown resulting in a reading across it from end to end..in other words hot to ground..hope you understand..if not then get someone to explain it further
you will NOT get a reading from one end of a cartridge fuse to the other end if it is good because it's just like baring a hot wire and measuring at two locations along it's length
Old 03-30-2013, 12:17 AM   #24
Lol, true true.
Commercial freezer Grounding/Neutral help LFYN HVAC 38 02-07-2013 08:19 AM
kenmore fridge too warm, freezer iced up tarbash11 Appliances 5 06-30-2011 11:32 PM
Kenmore 596 bottom freezer cold top warm klimshelf HVAC 2 03-30-2011 09:32 AM
Freezer odors - coming from blower/fan Richo Appliances 3 05-27-2009 06:26 PM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 10:55 AM
