Walk In Cooler - HVAC - DIY Chatroom Home Improvement Forum
Old 02-11-2010, 10:29 AM   #1
Walk in cooler
I'm planning on purchasing a used walk in cooler for a medium temp application. I have seen some coolers without refrigeration equipment go for pretty low prices. Has anyone disassembled one of these and reassembled one. I'm wondering how well the panels fit back together or if there was any problems. If I go with just used panels, I will have to design and install a new refrigeration system. I'm not sure if this would be worth the cost. Does anyone know a ball park figure for an 8k btu/hr condensing unit and evap? My other option would be to find a used cooler with refrigeration.
pomelo is offline   Reply With Quote
Old 02-11-2010, 12:15 PM   #2
Rewards Points: 502
Yes, it wasnt too painful at all. As long as you have all the parts and none of the interlocking tabs are broken, you should be fine.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 02-11-2010, 12:24 PM   #3
yummy, lots of beer storage
billy_bob_3 is offline   Reply With Quote
Old 02-11-2010, 04:16 PM   #4
Shouldn't be to bad as long as the floor is level before you start if not the cam locks sections will give you trouble.
I'd have some good silicon caulking or foam on hand just in case.
The manufacturer should have a stamp or tag somewhere if you need parts they are readily available.
Pricing hard to say, not suppose to prices items on DIY.
SULTINI is offline   Reply With Quote
Old 02-11-2010, 05:01 PM   #5
An old Tradesmen
Rewards Points: 8,234
As Sultini said. A level floor is important.
I usually mark the panels before disassembly. Makes it easier to reassemble.
Old 02-11-2010, 07:32 PM   #6
Does anybody have any recommendations on doing a heat load on it? I was going to go through HeatCrafts engineering data. I'll then compare it to some of the load calculation programs.
Removing swamp cooler control Pharmjae Electrical 3 02-10-2010 03:36 PM
Swamp cooler vents Summiteer HVAC 4 02-04-2010 04:59 PM
HELP walk in cooler not hittinG 41degress bajaeddie Appliances 2 06-30-2008 04:47 AM
HELP walk in cooler not hittinG 41degress bajaeddie HVAC 2 06-24-2008 06:01 PM
Swamp Cooler vs AC mtcone HVAC 3 05-19-2008 02:43 PM
