W1 W2 / -Honeywell Thermostat- Help Connecting - HVAC - DIY Chatroom Home Improvement Forum
Old 01-02-2011, 06:56 PM   #1
W1 W2 / -Honeywell Thermostat- help connecting
We just bought a Honeywell Programmable thermostat with touch programming. Our old mercy system had a W1 and W2 wiring as well as G, Y, E, O, C T R, F. The manual says if we have W1 /W2 wiring contact a contractor, is there a way we can connect it ourselves without a contractor?
Stanzalady is offline   Reply With Quote
Old 01-02-2011, 07:09 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
what model t-stat did you buy? give some info on your system. A/c, heat pump, backup heating electric or gas
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-02-2011, 09:40 PM   #3
Try: www.customer.honeywell.com , they typically have every manual available; operational, installation and several languages...to be 'Politically Correct' and all...
Filters&More is offline   Reply With Quote
connecting a 4 wire SP thermostat to a 2 wire system wiichkin Electrical 4 08-15-2010 02:35 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 05:19 PM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 05:43 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
