W/O Heat - Armstrong Air Ultra 5 Tech 80 - HVAC - DIY Chatroom Home Improvement Forum
Old 12-29-2013, 07:22 PM   #1
Hello,
I'm currently in the process of converting my attic to an extra bedroom. In the process of moving the furnace, we kinked one of the copper A/C lines and believe there'd be a leak. We plan on replacing the 3/8 & 3/4 lines in a couple of days, but we'd like to hook the furnace back up tonight so we could have access to heat again. With that being said, is it viable to just hookup the furnace without having the two A/C copper lines plugged back in?
dp24 is offline   Reply With Quote
Old 12-29-2013, 07:41 PM   #2
HOTDAWG
You can hook up the furnace, I would shut the breaker off for the AC though to ensure that it can't be kicked on accidentally otherwise it will cause damage to the compressor
Affordable Comfort, assisting with furnaces Barrie and surrounding area, as well as offering 24 hour furnace repair
Acomfort is offline   Reply With Quote
Old 12-29-2013, 07:43 PM   #3
Rewards Points: 582
Originally Posted by dp24 View Post
Hello,
1 st yes you can hook up furnace....but make sure your not leaking freon at the kink in the line..that would be very dangerous.....ben sr......picture would help..
Old 12-29-2013, 08:11 PM   #4
When we moved the furnace, we broke the line and all the air pressure leaked out for approximately 2 minutes. (But no liquid came out.)
Old 12-29-2013, 08:37 PM   #5
Rewards Points: 616
well dont tell the refrigerant police....lol
carmon is offline   Reply With Quote
The Following User Says Thank You to carmon For This Useful Post:
ben's plumbing (12-30-2013)
Old 12-29-2013, 08:38 PM   #6
Thanks for the prompt replies
Armstrong Air Ultra V Tech 80 problem... wont stay on :( Kassy HVAC 12 11-10-2012 06:09 PM
Armstrong ULTRA 5 TECH 80, Model No. 45647-001 BTUs? _scott HVAC 3 03-26-2011 10:35 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
armstrong air ultra v tech 80 furnace model C2E24A-1A Iowachick HVAC 1 11-29-2008 06:15 PM
