Voltage Drop At Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 06-25-2009, 11:18 AM   #1
fastback4's Avatar
Rewards Points: 51
Voltage drop at thermostat
I get 28v at the furnace controller at the R and C (red & blue wire) posts. At the thermostat i get 8v at the R & C (red & blue) wires. White,Green & Yellow are 28v. Is this normal or is this bad....Regards......Tom
fastback4 is offline   Reply With Quote
Old 06-25-2009, 02:01 PM   #2
Is the common {C} terminal on the thermostat wired to the furnace. 28v between R and W,Y,and G is normal if the stat is not calling for heat or cool or fan.
SKIP4661 is offline   Reply With Quote
Old 06-25-2009, 02:48 PM   #3
fastback4's Avatar
Rewards Points: 51
The common C wire (blue) is wired to the furnace controller but not wired to the thermostat. I've been told this common blue wire will need to be used if i upgrade my thermostat to a programmable lcd readout type thermostat. Is this a fact?.........Tom
Old 06-25-2009, 05:44 PM   #4
http://www.hvacmechanic.com/tstatwiring.htm
Post a schematic of 'stat to furnace wiring. We will find the missing 20vac.
Remote sensor for line voltage thermostat? hbridge HVAC 7 07-06-2012 04:42 PM
how to wire a low voltage thermostat to a baseboard heater db3iii HVAC 4 06-05-2009 09:03 PM
Low voltage thermostat wiring dirtpig538 General DIY Discussions 2 02-14-2009 01:48 PM
Voltage drop fix I discovered... rgsgww Electrical 12 12-09-2008 06:21 PM
Voltage Drop Issues sushiboy Electrical 12 04-03-2008 10:01 PM
