VisionPro Outdoor Sensor Reading Inaccurate - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-20-2011, 06:48 PM   #16
You would need to search the honeywell site to see if they have a dual fuel wireless setup.
Master of Cold is offline   Reply With Quote
Old 09-20-2011, 06:56 PM   #17
An old Tradesmen
Rewards Points: 8,142
Run a new separate wire for the sensor, before you just go out and buy a new thermostat.
Even with the resistance reading correctly, the blower motor can interfere with it.
Old 09-20-2011, 07:01 PM   #18
You could do this the old fashioned way with a seperate box outside to switch from hp to fossil fuel.
Old 09-21-2011, 06:41 AM   #19
AKA HVACTECHFW
Rewards Points: 1,208
Honeywell prestige IAQ acts as the fossil fuel kit and has a wireless outdoor sensor. Very pricey though!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-11-2011, 08:04 PM   #20
I ended up going with the Prestige with the wireless outdoor sensor. It was a little more than I expected to spend on a Thermostat, but so far, I actually like it much better than the old one. Installation and set-up was fairly easy, plus I didn't have to fish wires through the walls. After taking the old VisionPro off the wall, I hooked the outdoor sensor up directly to it (it was still running on battery power) and the sensor was still reading about 20 degrees high. Evidently, the issue was something within the thermostat, which may have been caused originally by the improper wiring. Thanks to everyone for you input.
bstone17901 is offline   Reply With Quote
Old 10-12-2011, 06:59 AM   #21
Thanks for the follow-up. Glad it worked out for you.
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Honeywell VisionPro IAQ YTH9421C1002 Wiring Help jond777 HVAC 0 11-22-2010 09:22 PM
Heat does not turn off with new VisionPro HoneyPro HVAC 25 10-21-2010 12:40 AM
Honeywell VisionPro Thermostat infoskr HVAC 32 12-17-2008 03:44 AM
VisionPro Thermostat? kcrossley2 HVAC 3 01-27-2007 07:39 PM
