Old 02-06-2013, 10:59 AM   #1
VisionPro IAQ Thermostat
I have a IAQ tstat connected to a new YP9C modulating furnace. In the setup for the tstat it ask how many stages the furnace has. How do I answer this with it being a modulating furnace. Also the IAQ is asking about the cycles per hour to set each stage. I have went to the dealer about this, but when he set it up the first time, he just set it up using the letter E. Thanks for the help...
Harry9872 is offline   Reply With Quote
Old 02-06-2013, 06:15 PM   #2
An old Tradesmen
The IAQ can't control the modulation of your furnace. So set the IAQ to 1 heat. York says to set the CPH to 6. I find they tend to work better set to 3.
Old 02-07-2013, 12:12 AM   #3
Experienced HVAC Tech
i installed one of these today and set to 4 cycles per hour simply because of the houses size and age.
HVAC1000 is offline   Reply With Quote
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
VisionPRO Setup Functions & Heat Pump infoskr HVAC 31 03-18-2010 02:15 PM
Honeywell VisionPro Thermostat infoskr HVAC 32 12-17-2008 04:44 AM
VisionPro Thermostat? kcrossley2 HVAC 3 01-27-2007 08:39 PM
