Vision Pro Stat Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 11-08-2009, 02:30 PM   #1
Rewards Points: 29
vision pro stat wiring
I put a vision pro 3 stage heat/2 stage cool in my father in-law house after he had a new air handler and heat pump installed .I replaced a white rodgers 2 stage heat/1 stage cool stat.My question is when I hooked it up the directions made it seem like the HP would go on aux heat and the heat strips would go on the EM heat.My question is having the wire on the o/b terminal, will it make the HP run in heating mode with out havingthe heat pump wired to aux heat. .Because I would think if they are saying 3 stages of heat then the heat pump would run off of the o/b terminal and 2nd stage off the aux and 3rd stage off the em.I talked to honeywell about it and they said the heat strips are jumpered together off of the 3 stage em heat.So i just want a opinion on if this seems right.
Thank's Joe
jsmith929 is offline   Reply With Quote
Old 11-08-2009, 02:44 PM   #2
Retired from the grind
Rewards Points: 6,652
Look at the book for the air handler, then match the wire colors on the unit, to what the air handler book states. Then draw a schematic of both the thermo & air handler & match wires to correct terminals. This is why manufacturers have directions, and why HVAC techs are paid to repair home owner foul ups.
Old 11-08-2009, 03:35 PM   #3
Houston204's Avatar
Rewards Points: 556
If you have a 2 speed heatpump with aux heat you will have 3 stage heat.
Most applications will not have 3 stage heat.
The emergency heat terminal will not get energized in heat mode regardless of how much demand that you have. It will only be energized in emergency heat mode.
In emergency heat mode the stat will energize E untill demand is greater than 2 degrees, at which time it will then also energize Aux.
Y (compressor) energized along with G (fan) and lack of O is first stage heat. (or B also energized for Rheem/Ruud)
Houston204 is offline   Reply With Quote
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
t stat wiring problem Tinman_iii HVAC 4 06-02-2009 09:26 PM
Honeywell stat wiring w/ Trane furnace JaePee HVAC 7 01-18-2009 06:50 AM
LUX digital stat Trane XE80 intermittant problem rossl56 HVAC 6 12-26-2008 05:53 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
