Vision Pro 8000 Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 01-25-2009, 03:56 PM   #1
Vision pro 8000 problem
I recently ordered a Honeywell Vision Pro 8000 model TB 8220. I tried to install it and my old thermostat has Aux heat and Emergency heat. The 8200 does not have a hookupp for the emergency heat and aux heat wires.
I belive that I need a different Vision Pro model 8000 TB 8320 ?? as this model may have the other correct inputs for my wires.
Charlie
chucky7 is offline   Reply With Quote
Old 01-25-2009, 05:15 PM   #2
Dr Heat's Avatar
Charlie
call Gary @ 1 312 259 9237 he is a Honeywell Rep (do not tell him I gave you the number)
Dr Heat is offline   Reply With Quote
Old 01-25-2009, 08:21 PM   #3
An old Tradesmen
Rewards Points: 6,112
For a house.
You don't want a TB series thermostat, thats for commercial applications.
You want TH for residential. Very big difference in them.
Or, you could use the YTH9421(IAQ).
Neutral problem, not sure what to do now BataviaJim Electrical 37 01-03-2009 12:00 PM
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 07:10 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
