Very Old Gas Furnace Won't Turn On -- WE'RE FREEZING! - HVAC - DIY Chatroom Home Improvement Forum
Old 01-04-2011, 10:55 AM   #1
very old gas furnace won't turn on -- WE'RE FREEZING!
I have an International Heater from the 50's in my home that won't turn on this morning. I jumped the thermostat wires at the stat and that didn't work, the pilot is on, the breaker is on, the emergency shut off is on, I can manually turn the fan on, but I can't get the heat on. Any ideas on where to start?
Here's a
jimsimm is offline   Reply With Quote
Old 01-04-2011, 11:26 AM   #2
Look for a reset button. Usually red. Sounds like a upper limit switch opened. Check filter if it resets
semore 102 is offline   Reply With Quote
Old 01-04-2011, 11:38 AM   #3
I don't see any reset button. I'm looking for my multimeter so I can check the voltage at the valve. If the pilot is lit, as it is, do I need to check the thermocoupler or would that not be an issue since the pilot is lit?
Old 01-04-2011, 11:52 AM   #4
In your picture. The white button/ switch. Is that a reset. Look up into the hood , see if reset is there. Gas valve should be getting the 24 volts. Open circuit somewhere.
Old 01-04-2011, 12:15 PM   #5
thanks semore, that white button is the manual switch for the fan. the fan works when I turn that. I checked the gas valve and it is not getting any voltage. Where do I go from there?
Old 01-04-2011, 12:24 PM   #6
Do you see the wiring diagram. Look for a upper limit switch. You looked in the hood? Follow the wires from the gas valve, look for any resets.
Old 01-04-2011, 01:14 PM   #7
Looks like an in-line fuse coming off from the transformer on the red wire. If it is a fuse, check to see if it is burned. When you find your meter check the transformer for 24 volts.
SKIP4661 is offline   Reply With Quote
Old 01-04-2011, 01:33 PM   #8
Thanks for everyone's reply. I re-tested everything, and it turns out the Thermostat IS faulty. I don't know why it didn't turn on the first time I tried jumping it, but it did now. Off to the store to get a new one. Thanks again for your help.
Old 01-04-2011, 03:47 PM   #9
That is an oil converted to gas furnace. I t has no resettable limits.
hvaclover is offline   Reply With Quote
Old 01-04-2011, 03:50 PM   #10
The white button is for continuous fan and is part of the fan limit control.
Old 01-04-2011, 03:53 PM   #11
Not a fuse. Just an insulated fork terminal.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Comfortmaker furnace won't turn on steelframe8459 HVAC 36 11-30-2011 03:22 PM
problem with furnace will not turn on or works by itself tech2002 HVAC 3 12-29-2010 03:36 PM
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 03:27 AM
Furnace w Cooling unit wont turn off Klatimer HVAC 2 09-19-2008 08:35 PM
