A Very Odd Problem With Central Air Conditioner - HVAC - DIY Chatroom Home Improvement Forum
Old 03-14-2006, 02:22 PM   #1
a very odd problem with central air conditioner
this started happening at the end of last summer, i am not sure which a/c i have, but i have a carrier furnace system and a manual thermostat.
the problem is everytime i set the thermostat to cool it the furnace board fuse will burn out. i have no problems with switching to off or heat.
and the fuse doesnt take a while to burn, it burns instantly. i am thinking it would be electrical, but since i dont know anything about wiring and which wire is for a/c, i am not able to tell if the wiring is loose or cut.
if any further information is required please let me know.
cooldragonshome is offline   Reply With Quote
Old 03-16-2006, 06:16 AM   #2
weinstall.ca
Post
air conditioning blowing fuses
You problem lies in a short in the cooling section of your wiring.
Remove your thermostat and make sure you do not have any wires touching on the ac side of the thermostat.
The cooling wire usually will be black or yellow ,Dependending.
Also make sure that it is not shorting out in the wall.
You will have to ohm out the wires
Allan Thorne
Clarkson Comfort Zone Heating and Air Conditioning Mississauga Ontario
weinstall.ca
allan is offline   Reply With Quote
Old 03-18-2006, 02:47 PM   #3
sub-contractor
call a service tech. there are way too many things to list. bad ground, improper wiring, bad board, squirrel chewing wires outside, etc.....)
Aceinstaller is offline   Reply With Quote
Old 06-14-2015, 06:30 PM   #4
Rewards Points: 1,989
You may also have a short anywhere from the tstat to the furnace to the condenser unit ( outside ) to inside the condenser .
Just a stab in the dark , but go outside and see if the tstat wire from the furnace to the condenser , is exposed . If it is , did it get chewed in tow by a pet or a weed eater ?
God bless
Wyr
WyrTwister is offline   Reply With Quote
The Following User Says Thank You to WyrTwister For This Useful Post:
ben's plumbing (06-14-2015)
Old 06-14-2015, 06:56 PM   #5
Rewards Points: 582
disconnect the wire from the y terminal and c terminal on control board ..set t stat to cool see if it still blows fuse .. if fuse don't blow... problem is in control wire to condenser or contactor....
Old 06-14-2015, 06:59 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 1,454
2006 was a good year for rodents chewing wires.
The Following 4 Users Say Thank You to yuri For This Useful Post:
Bitters (06-15-2015), InPhase277 (06-15-2015), nap (06-14-2015), zappa (06-14-2015)
Old 06-14-2015, 07:03 PM   #7
Rewards Points: 582
yep don't you just feel like a jack ass when that happens
Old 06-14-2015, 07:06 PM   #8
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Wyr twister
This is at least 2 ancient threads you have revived. Having some issues somewhere in life that cause you to not realize the dates when the threads were started?
Old 06-14-2015, 07:06 PM   #9
Would make me feel like getting a cat . A hungry one .
God bless
Wyr
Capacitor Replacement on Central Air unit sn2567 HVAC 6 07-21-2012 03:29 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
central air wont kick in? What have I done HVAC 3 08-14-2006 03:03 PM
winterizing a central air conditioner Buckeyefan7 HVAC 2 11-29-2005 10:11 AM
Installing Central Air using existing heat ducts lvlacic HVAC 2 06-25-2005 01:47 AM
