I have a Weil McLain CGM Boiler Series 9. It is a 2 zone and is about 22 years old. The problem I am having is that there is very little heat coming out of my baseboard units.
On the pressure guage it is reading 15psi and the temp is 220.
Complete noob so any and all help is much appreciated
220 wow. Circulator pump is either a big red pump or 2 smaller ones. I going with probably b and g 100 series. Put your hand on it. Is it running. Your psi is ok for a one story house. Water temp is extremly high at 220.
If this is correct, then it is really hot to the touch. I don't think it is working because I don't feel it vibrating. Also the copper pipe coming out of it is cool to the touch.
The temp did go down to about 160 earlier and is now up to 180
Also it is a split with the 2nd zone in the finished half of the basement
OK when it fires it drops to 160 but when idle it climbs to 220
If the pipes are cold you found your problem. Those pipes should be HOT. Something is going on with circualtor pumps. Time to call your furnace man.
Point being this. The water temp. you said 160 should be going through those pipes. HOT. Burn yourself touching those pipes. Its not circulator is the problem.
I'd like to confirm..
Do you have two separate pumps or one? You can use the handle of a screwdriver against your ear and place the other end on a pump to listen like it's a stethascope. Are both making their own noice.
Do any of your baseboards work?
Do you have bleed valves on the ends of the baseboards that allow you to bleed off excess air?
ooppps
Just saw the last post mentioning the two pumps. It would be unusual to have both pumps fail at the same time, which was why I was asking if any of the baseboards were heating. If bleeding the baseboards doesn't correct the problem then your back to looking at why the pumps are not doing there jobs.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
