-   -   Very Little Heat From Boiler (http://www.diychatroom.com/f17/very-little-heat-boiler-170418/)
villock 01-28-2013 06:39 PM
Hi all, hoping for some help
I have a Weil McLain CGM Boiler Series 9. It is a 2 zone and is about 22 years old. The problem I am having is that there is very little heat coming out of my baseboard units.
On the pressure guage it is reading 15psi and the temp is 220.
Complete noob so any and all help is much appreciated
Dennis
joecaption 01-28-2013 06:53 PM
Is the cirulating pump running?
Is the boiler firing?
villock 01-28-2013 07:10 PM
How do I know if it is running? Sorry, don't know about this stuff
Yes the boiler is firing
747 01-28-2013 08:40 PM
220 wow. Circulator pump is either a big red pump or 2 smaller ones. I going with probably b and g 100 series. Put your hand on it. Is it running. Your psi is ok for a one story house. Water temp is extremly high at 220.
villock 01-28-2013 09:12 PM
Each zone has a circulator pump correct?
If this is correct, then it is really hot to the touch. I don't think it is working because I don't feel it vibrating. Also the copper pipe coming out of it is cool to the touch.
The temp did go down to about 160 earlier and is now up to 180
Also it is a split with the 2nd zone in the finished half of the basement
OK when it fires it drops to 160 but when idle it climbs to 220
747 01-28-2013 10:50 PM
If the pipes are cold you found your problem. Those pipes should be HOT. Something is going on with circualtor pumps. Time to call your furnace man.
Point being this. The water temp. you said 160 should be going through those pipes. HOT. Burn yourself touching those pipes. Its not circulator is the problem.
villock 01-28-2013 11:05 PM
Thanks for the replys, much appreciated. The pipes are not cold all the time. Right now this zone pipe is warm to hot. Earlier is was barely warm
So will replacing this solve the temp problem? And should I shut it down until I replace it?
I replaced this circulator pump about 5 years ago. The other one on the 2nd zone is the original one
how 01-28-2013 11:37 PM
I'd like to confirm..
Do you have two separate pumps or one? You can use the handle of a screwdriver against your ear and place the other end on a pump to listen like it's a stethascope. Are both making their own noice.
Do any of your baseboards work?
Do you have bleed valves on the ends of the baseboards that allow you to bleed off excess air?
how 01-29-2013 12:21 AM
ooppps
Just saw the last post mentioning the two pumps. It would be unusual to have both pumps fail at the same time, which was why I was asking if any of the baseboards were heating. If bleeding the baseboards doesn't correct the problem then your back to looking at why the pumps are not doing there jobs.
747 01-29-2013 10:28 AM
Originally Posted by how (Post 1104683)
ooppps
Exactly i'm thinking something electrical to the pumps
beenthere 01-29-2013 04:35 PM
Could be frozen pipes.
