Verifying Vent Fan Ductwork - HVAC - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 11:37 AM   #1
Rewards Points: 366
Verifying vent fan ductwork
If I posted in wrong forum, let me know.
I wanted to know if I wanted to verify non-furnace or AC related ductwork is working properly (no leaks for water or air) from the home's ceiling all the way up to roof, who should I get to inspect that?
Someone from an HVAC installer/repair shop? A general contractor? Or a roofer?
The ductwork I want to check are the bathroom and laundry vents, and kitchen range hood vent. Want to make sure they're not leaking and particularly kitchen vent is not venting/recirculating the air/odors into attic due to leakage in ductwork.
daluu is offline   Reply With Quote
Old 01-31-2012, 08:10 PM   #2
HVAC Tech/ Browns Fan
Get a general contractor
Tator1076 is offline   Reply With Quote
Old 01-31-2012, 08:46 PM   #3
Rewards Points: 13,740
Why not check it yourself? Not much to it just go in the attic and look to make sure there was foil tape on the seams, look for stained sheathing.
If you do not feel safe on a ladder then get a roofer to check out the sealing on the roof.
Old 02-01-2012, 12:57 AM   #4
Rewards Points: 366
I am thinking to check myself, just wanted to know who to call in case I wanted someone else to check.
New Roof marknok Roofing/Siding 4 08-06-2011 11:41 AM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
Exterior Ductwork for a Dryer vent lappin_jeff Appliances 9 09-27-2009 07:48 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 07:15 PM
