Venting Two Adjacent Bathrooms - HVAC - DIY Chatroom Home Improvement Forum
Old 03-16-2008, 10:09 PM   #1
Venting two adjacent bathrooms
My wife and I are in the throws of a remodel. I have two bathrooms that are side by side in to each which I'll be installing a heater/vent combo.
To avoid punching more than one hole in my roof to allow venting, can I have them vent through a single outlet? If so, what do I physically need in the way of ducting etc. a "Y" or a "T". How do I keep the exhaust from one bath going into the other?
Each of the units in question vents through a 4" opening.
Randell Tarin is offline   Reply With Quote
Old 03-17-2008, 08:33 AM   #2
30 year tech
hvac122's Avatar
You can do it with one vent out. Use a Y. Make sure that the outlet on the Y will handle the CFM for both fans. 4" will only handle one fan at a time. Also the termination vent will need to be larger.
hvac122 is offline   Reply With Quote
Old 03-17-2008, 07:00 PM   #3
Search in Google and use " bathroom exhaust fans' there are companies that make this specific item.
sammyjk1 is offline   Reply With Quote
Furnace venting questions Mastiff HVAC 9 12-05-2012 05:51 PM
Can I T my new dryer's exhaust into my bathrooms exhaust? Felipon Appliances 2 01-30-2008 06:53 PM
supply runs required in all bathrooms? bjherron HVAC 2 11-23-2007 07:56 AM
Design rules for wood floors in adjacent rooms chrish Flooring 1 09-10-2007 07:04 PM
Venting TonyD Plumbing 11 01-18-2007 06:31 PM
