Venting Through Floor Joist - HVAC - DIY Chatroom Home Improvement Forum
Old 02-21-2011, 11:21 PM   #1
venting through floor joist
My question is the way they vented my 95 % Goodman furnace is out the side of my house with one pipe. What I would like to do is use a concentric vent, my problem is the floor joist go the wrong way. Can I cut through the joist ,or will that weaken the structure. It would be at the end of the joist near the corner of the wall.
bignezzy74 is offline   Reply With Quote
Old 02-22-2011, 04:09 AM   #2
An old Tradesmen
Rewards Points: 6,550
Don't cut floor joist.
Old 02-22-2011, 08:52 AM   #3
MikeKy55's Avatar
Rewards Points: 254
You might post some pictures for the guys to review. My vent runs along under the joists about 10 feet and then turns 90 and then has two 45 fittings that take it up between two joist and out the back of the house.
On the concentric, I'm sure some guys think they are fine in a horizonal position, but I removed mine and ran two separate pipes in it's place. I was having intake air problems and when I removed the concentric to install the two pipes, I found the lower 30 to 40% of the intake area filled with grass clippings and spider webs. This concentric was located about 3.5 feet from the ground and was behind shrubs. So clippings from mowing were not being blown in it's direction. It was collecting them out of the air.
OH, I agree 'don't cut the joists'
MikeKy55 is offline   Reply With Quote
Venting ponch37300 Plumbing 41 02-23-2013 11:37 PM
Venting a sink pump WillK Plumbing 2 12-26-2010 02:21 PM
Gas furnace venting Qs (non high eff) WallyWoggle HVAC 6 12-09-2010 07:41 PM
I want to maximizing venting, diagram included. cbzdel Roofing/Siding 3 07-28-2010 05:55 AM
Soffit venting vs. DCI Smart Vent JDPII Roofing/Siding 1 02-28-2009 09:42 PM
