Old 08-29-2012, 09:57 AM   #1
Venting over the range convection oven question
Hi everyone. Just a quick question regarding the proper way to vent an over the range convection/microwave oven. I am actually pretty sure this is an extremely dumb question but i have to ask to put my mind at ease so im not worried about my family while im at work. I will be venting the oven with rigid 6" round duct. I plan on running this into the attic above the kitchen and then routing it to the nearby sofit. My dumb question is, are there any concerns about this vent pipe being in contact with insulation? I was not sure if this exhaust duct would be capable of creating any kind of fire hazard. My apologies about the question and thank you all in advance for any advice.
johncle6023 is offline   Reply With Quote
Old 08-29-2012, 11:41 AM   #2
It needs to be vented out the roof not the soffit.
You can use fire block expanding foam or caulking to seal where it goes through the sheetrock.
Only time it would be a fire hazard is if the stove was on fire.
Old 08-30-2012, 08:40 PM   #3
30 year tech
hvac122's Avatar
It would be fine going out the soffit if there is room. Make sure its insulated. The pipe is fine laying on the insulation.
Its A Good Life!
hvac122 is offline   Reply With Quote
The Following 2 Users Say Thank You to hvac122 For This Useful Post:
ben's plumbing (08-31-2012), oh'mike (08-30-2012)
Old 08-31-2012, 08:31 PM   #4
Thank you very much for the reply hvac122. I really appreciate it. what are you referring to when you say "make sure it is insulated"? Does the exhaust need to be double walled pipe or will the normal ducting that you would use to run a standard hvac supply line be OK? Thanks again
Old 08-31-2012, 09:30 PM   #5
30 year tech
hvac122's Avatar
Single wall pipe is fine. It needs to be wrapped or sleeved with r8 duct insulation if not in a conditioned space.
Its A Good Life!
Built in oven and cooktop wiring question Shanereav Electrical 6 12-03-2011 05:50 AM
question on 240 wire size and ground for wall oven twobyfour2 Electrical 8 04-30-2011 08:13 AM
Yet another bathroom exhaust fan venting question JulesB HVAC 23 03-10-2011 04:16 PM
Range Hood Venting Considerations RyanPaq HVAC 0 11-12-2010 03:52 PM
Venting question. Bcoleman6 Plumbing 7 03-21-2008 04:41 PM
