Venting An Oven Range Microwave - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 03-02-2012, 09:32 AM   #31
Originally Posted by COLDIRON View Post
Yes checkout his pictures, let me check my ductalater.
We're not talking heating and cooling here we're talking just exhausting a little smell and steam from cooking, don't have to maintain temperatures and humidity and how many microwaves are vented with just recirculating rather than exhaust ? They do absolutely nothing.
Wrong and wrong. Above the range microwaves sit fairly close to the cooktop compared to range hoods. They are able to maintain this reduced clearance by by being capable of moving a certain amount of heat when things get going on the cooktop. Doesn't matter if you vent that heat outside or if you use the recirc option and vent it out into the room away from the cooktop, you are still moving a prescribed amount of heat from a critical area. These microwaves even have a overide thermostat that turns on the fan automatically when things get hot just in case you forget.
mpnret is offline   Reply With Quote
The Following User Says Thank You to mpnret For This Useful Post:
ben's plumbing (03-02-2012)
Old 03-02-2012, 10:13 AM   #32
30 year tech
hvac122's Avatar
I agree. These are designed to move approximately 300 CFM either way.
hvac122 is offline   Reply With Quote
The Following 2 Users Say Thank You to hvac122 For This Useful Post:
ben's plumbing (03-02-2012), Canucker (03-02-2012)
Old 03-02-2012, 10:14 AM   #33
Thread killer
Rewards Points: 272
How many cfm does the range move? If its much more than 250, 4" won't work very well. Can you still do it? Sure. But you're going to have some blowback because the vent isn't capable of exhausting as much as it flows, plus the added noise and wear on the fan, as hvac122 pointed out. If it were me, and the wall is open, cut out the brick and install a proper sized exhaust. Its not going to be easier to do it later
Canucker is offline   Reply With Quote
Old 03-02-2012, 10:29 AM   #34
demandrew's Avatar
Rewards Points: 97
I guess the nature of these forums is that you have to work your way through varying opinions. But I think I like the sound of the last few comments the best.
I'm going to break open my wall a bit more to allow room for a proper sized vent. It will also let me move the mircowave slightly to the left which is a bonus. And I also want to learn how to do it, so why not take the opportunity and then be content to know that it's all vented properly.
Thanks for all the advice. I'll post some pics when it's all done!
demandrew is offline   Reply With Quote
Old 03-02-2012, 07:03 PM   #35
DIY staff
Rewards Points: 7,174
No one will criticize your work if you do it right---Keep us posted---you will be fine---
Old 03-02-2012, 09:39 PM   #36
Rewards Points: 582
yes opinions vary..buy doing it right is truly the best option there is...as mike said keep us posted...
Old 03-03-2012, 06:09 AM   #37
Rewards Points: 1,216
I think this is the kind of microwave I'll be getting. I have a 3 1/4 x 10" vent but i would only be able to pass it through a 4" pipe to the outside. I know that they often require higher but I'm wondering if this 4" will just squeeze by and at the very least be better than not venting at all.
The answer to your question is Yes.
COLDIRON is offline   Reply With Quote
Old 03-12-2012, 10:24 AM   #38
demandrew's Avatar
Rewards Points: 97
Thanks again for everyone's input. There have been interesting developments. I ended up putting in a new 3 1/4 x 10" vent. It was a pretty daunting task at first, but I managed my way through it.
If you care to take a look you can read about it in my ongoing project showcase: My full kitchen remodel! Lots of improvisation mixed with IKEA and exposed brick
Take a look at the whole showcase if you like, and feel free to leave feedback, but the vent specific posts begin towards the end of page 2.
If you want to avoid any reading you can also just look at the photos here:
http://www.diychatroom.com/members/d...-kitchen-vent/
Old 03-12-2012, 11:27 AM   #39
Not so new
12penny's Avatar
Rewards Points: 520
Be proud...nice job.
12penny is offline   Reply With Quote
Old 03-12-2012, 07:08 PM   #40
Rewards Points: 1,580
Well done! Looks good. Time to go into the business I guess.
bob22 is offline   Reply With Quote
Old 03-12-2012, 09:42 PM   #41
demandrew's Avatar
Rewards Points: 97
Thanks for the kind words! Not sure if I'm ready for the business just yet, but thanks for the encouragement.
Old 03-12-2012, 09:47 PM   #42
Rewards Points: 582
really nice job...how high up is that?
Old 03-13-2012, 05:51 AM   #43
Looking Good just like a Pro did it.
Old 03-13-2012, 11:01 AM   #44
demandrew's Avatar
Rewards Points: 97
Hey thanks. I would say it's about 20' up. It's for a kitchen on the second floor. The height wasn't a problem for me, just the steepness!
Old 03-13-2012, 11:02 AM   #45
demandrew's Avatar
Rewards Points: 97
Thanks. Maybe that's what I'll tell people and see if I can fool them. How much do you think a pro would charge for a job like this? It took me a long time to complete but I imagine they could bop it out in half a day or so.
Oven Range Microwave lstamour Appliances 1 11-30-2011 03:13 PM
Roper Electric Oven Range Problem mcnutty Appliances 6 07-05-2011 05:32 PM
replaceing a over the range microwave oven leeps Appliances 1 06-17-2010 11:46 PM
over the range microwave oven cmellinger Appliances 3 12-24-2009 12:36 PM
Venting of a microwave oven into attic. BobLink General DIY Discussions 2 09-07-2009 04:20 PM
