Venting An Oven Range Microwave - HVAC - DIY Chatroom Home Improvement Forum
Old 02-27-2012, 10:00 PM   #1
demandrew's Avatar
Rewards Points: 97
Venting an oven range microwave
This seemed like the best section to post this question, but forgive me if I was mistaken..
I'm thinking about installing an oven range microwave and of course my preference would be to vent it outside (I find the idea of recycling in room to be strange..)
The problem is this: The kitchen that I'm redoing has an existing vent to the outside, but it is only a 4inch diameter vent. Perhaps it was once used for a dryer, or maybe their previous range hood was really crappy. I understand though that for most modern oven range microwaves 4 inches is rather inadequate.
Can anyone comment? Just how inadequate would 4inches be??
If your options are vent outside with 4inches or not vent outside at all...then perhaps 4 inches is better than nothing?
What do you guys think? I appreciate any advice you can offer here.
demandrew is offline   Reply With Quote
Old 02-27-2012, 10:10 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
For a range microwave a 4" pipe will be fine.
Look at the instructions provided for how to connect.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-27-2012, 10:15 PM   #3
check the requirements of the microwave. i just redid our kitchen and ran a 6 inch line for the vent hood as per the microwave installation instructions.
Old 02-27-2012, 10:59 PM   #4
how
Rewards Points: 1,070
I am assuming that this is a fan assist vent? If not, maybe you should tell us where this vent goes & exits?
While 6 " makes for a quieter fan operation, 4" is better than nothing and the requirements for venting a microwave range isn't that high.
how is offline   Reply With Quote
Old 02-27-2012, 11:32 PM   #5
demandrew's Avatar
Rewards Points: 97
The vent would go from the back of the microwave through my brick wall and outside.
I'm tending to agree with the better than nothing appraisal.
Thanks for all the help
Old 02-27-2012, 11:40 PM   #6
Rewards Points: 12,830
I've installed at least 20 wall mount microwaves and not one had an outside vent. And 0 complants from customers.
Old 02-28-2012, 10:19 PM   #7
sktn77a's Avatar
Rewards Points: 360
If the microwave is going to vent the main cooking range below it, I would stick with a regular range vent and use a built in or countertop microwave. The vent fans in over-the-range microwave ovens are worthless.
sktn77a is offline   Reply With Quote
Old 02-28-2012, 10:47 PM   #8
30 year tech
hvac122's Avatar
If your talking about a micro hood microwave (fits above range with a vent fan inside) these are most often rated at 300 CFM and require a 6" or a 3 1/4 x 10" vent to the outside. They work fine for venting.
hvac122 is offline   Reply With Quote
The Following User Says Thank You to hvac122 For This Useful Post:
oh'mike (02-29-2012)
Old 02-29-2012, 12:48 PM   #9
demandrew's Avatar
Rewards Points: 97
I think this is the kind of microwave I'll be getting. I have a 3 1/4 x 10" vent but i would only be able to pass it through a 4" pipe to the outside. I know that they often require higher but I'm wondering if this 4" will just squeeze by and at the very least be better than not venting at all.
Old 02-29-2012, 01:29 PM   #10
30 year tech
hvac122's Avatar
It may work or may not. Could overheat and overwork the motor and will be louder.
Old 02-29-2012, 05:09 PM   #11
but it will be better than nothing at all.
Old 02-29-2012, 07:59 PM   #12
demandrew's Avatar
Rewards Points: 97
Thanks for the tips. I may just have to make do with the 4inches and consider it better than nothing as I'm not sure how comfortable I am enlarging the hole through my brick wall - unless some of you can convince me that it's a relatively easy and stress free job!
Old 02-29-2012, 08:02 PM   #13
Rewards Points: 1,528
I'm not sure how easy it will be to convert from the square 31/4" x 10" opening in the microwave to a 4" round in 31/2" or so? Is there a transition fitting made to do this readily available?
bob22 is offline   Reply With Quote
Old 02-29-2012, 09:11 PM   #14
Rewards Points: 582
I really don't like that better or nothing thougth....4" is to small ..as mentioned 3 1/4 x 10 or 6" round....is what is required... anything less is anybody's guess......how about code....
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 02-29-2012, 09:12 PM   #15
Rewards Points: 582
no because it won't work...well not right anyway...
Oven Range Microwave lstamour Appliances 1 11-30-2011 04:13 PM
Roper Electric Oven Range Problem mcnutty Appliances 6 07-05-2011 06:32 PM
replaceing a over the range microwave oven leeps Appliances 1 06-18-2010 12:46 AM
over the range microwave oven cmellinger Appliances 3 12-24-2009 01:36 PM
Venting of a microwave oven into attic. BobLink General DIY Discussions 2 09-07-2009 05:20 PM
