Venting For NG Direct Vent Fireplace In Basement - HVAC - DIY Chatroom Home Improvement Forum
Old 03-22-2011, 01:23 PM   #1
Venting for NG direct vent fireplace in basement
I'm about to get quotes for a Napoleon Natural Gas direct vent fireplace for the basement. The venting that will be used is 5"/8" flexible. Will they be able to vent between the rim joists? The rim joists are 9 1/2" tall and spaced 16".
Will that be sufficent spacing for Ontario Canada, or will they have to go through the foundation wall?
Cheers
fubar79 is offline   Reply With Quote
Old 03-22-2011, 02:05 PM   #2
The manual will tell you clearance to combustibles for that pipe typically 1"on sides and bottom and 3"on top. I would look into heat n glo fireplaces if they are available in your area
heatycooly is offline   Reply With Quote
Old 03-23-2011, 08:52 AM   #3
Thanks Heaty,
I had looked at the manual but missed that part. You were correct other then its 2" for sides and bottom while horizontal.
Why do you suggest heat n glo?
Old 03-23-2011, 11:16 AM   #4
Been installing heat n glo for years, have installed many different brands and I like that brand best
Old 03-23-2011, 12:18 PM   #5
Thanks for the info and suggestion. cheers
Do I need a HVAC return vent in basement? westing HVAC 13 04-03-2014 01:43 AM
Venting a new bath in basement jerryls Plumbing 9 03-04-2011 09:24 AM
Moving basement washer to first floor issues mazeroth Plumbing 2 02-05-2011 09:10 AM
Help with basement bathroom vent satchfan Plumbing 3 12-26-2010 09:35 PM
Direct Vent Fireplace SnoBird Building & Construction 1 03-19-2007 09:06 AM
