-   -   Venting for NG direct vent fireplace in basement (http://www.diychatroom.com/f17/venting-ng-direct-vent-fireplace-basement-99194/)
fubar79 03-22-2011 02:23 PM
I'm about to get quotes for a Napoleon Natural Gas direct vent fireplace for the basement. The venting that will be used is 5"/8" flexible. Will they be able to vent between the rim joists? The rim joists are 9 1/2" tall and spaced 16".
Will that be sufficent spacing for Ontario Canada, or will they have to go through the foundation wall?
Cheers
heatycooly 03-22-2011 03:05 PM
The manual will tell you clearance to combustibles for that pipe typically 1"on sides and bottom and 3"on top. I would look into heat n glo fireplaces if they are available in your area
fubar79 03-23-2011 09:52 AM
Thanks Heaty,
I had looked at the manual but missed that part. You were correct other then its 2" for sides and bottom while horizontal.
Why do you suggest heat n glo?
heatycooly 03-23-2011 12:16 PM
Been installing heat n glo for years, have installed many different brands and I like that brand best
fubar79 03-23-2011 01:18 PM
Thanks for the info and suggestion. cheers
