Old 02-01-2009, 04:18 PM   #1
Venting a microwave to the outside
We are trying to remodel our kitchen ourselves and have everything out, down to the studs. We can run the interior vent work from the microwave to the outside wall but we are not sure what is the best way to go through the wall. We have aluminum siding that we think has asbestos under it. Any suggestions?
K&Sremod is offline   Reply With Quote
Old 02-02-2009, 07:48 AM   #2
ccarlisle's Avatar
Gosh, first time I've heard of anyone venting a microwave...just what are you intending to cook in there that requires venting? and where to do vent from? the whole cabinet?
Shouldn't you be more concerned about how you're going to vent the stove?
ccarlisle is offline   Reply With Quote
Old 02-02-2009, 08:11 AM   #3
I think they're referring to a microhood. Wall mounted microwave with built in exhaust fan. Try to download the installation manual of the model you're looking to buy and see what they recommend for venting.
jerryh3 is offline   Reply With Quote
Old 02-02-2009, 08:16 AM   #4
ccarlisle's Avatar
Gotcha... sorry
Old 02-08-2009, 06:22 PM   #5
This guy needs to get out more. If resturaunts use vents why not homes? Maybe it's different in Canada
thiansky is offline   Reply With Quote
Old 02-08-2009, 06:50 PM   #6
Don't really understand your point?
Old 02-08-2009, 10:30 PM   #7
tomstruble's Avatar
you should get a competent siding contractor familiar with working with aluminum and asbestos .Is your house 1 story?can you vent thru the roof?
tomstruble is offline   Reply With Quote
Tags
construction, hvac, plumbing
More On This Topic
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. The budget is very important because that gives you an accurate idea of how much you're going to spend on the project and that way you can stay within that... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Something else you want to think about if you do decide to finish your basement in stages, is access to the plumbing and heating. If you decide to finish... Read More »
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. The insulation is a project that's very simple and and something I would actually suggest for a homeowner to try to do themselves. In this home here we... Read More »
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. Some of the common things you want to watch for in framing, is to make sure that all of your walls are plum, level and square. This keeps everything... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Okay, this is a great example of what happens in a lot of basements, where a homeowner starts to do their own work, hires one person to come in and he half... Read More »
Venting ponch37300 Plumbing 21 01-16-2009 06:56 PM
OTR Microwave installation bfarber Appliances 3 12-22-2008 08:55 PM
Venting OTR microwave smallcrpt Remodeling 3 11-11-2008 06:02 PM
Whirlpool Microwave light issue mustangcobra44 Appliances 8 08-14-2008 04:52 PM
Microwave Outlet Move Rsinc25 Electrical 3 11-22-2007 04:46 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
