Old 12-28-2006, 09:41 PM   #1
SnoBird
Venting A High Efficency Furnace
HELLO -- I want to install a new high efficency furnace in my ground floor condo (crawlspace below) Can the flue (exaust) pipe --vynil--pcv--or whatever you call it--be routed down about 4 ft to the crawlspace and then horizontaly about 12 ft to the outside? All of these I have seen have a blower in the exhaust system. I don't have access to the condo above.
Thanks for any help
SnoBird
SnoBird is offline   Reply With Quote
Old 12-29-2006, 06:12 AM   #2
There is a limit on how many bends (angles) and the length of the pipe. You would need to check with the manufacturer of the model that you may want to purchase.
Usually 3 right angles is the limit.
redline is offline   Reply With Quote
Old 12-29-2006, 08:05 AM   #3
NO! vent pipe of any make up can never go DOWN............
acefurnacefixer is offline   Reply With Quote
Old 12-29-2006, 07:13 PM   #4
furnaces vented with pvc have to be sloped back to the unit because the exhaust is so humid it will condensate. the condensate has to run back to the furnace and out to a drain.there is a 80% furnace that can vent down to exhaust but this wont help you in your home.
trollmastergeneral is offline   Reply With Quote
Old 12-30-2006, 09:59 AM   #5
???????????????????? What one? please enlighten me.
Old 12-30-2006, 11:00 AM   #6
adp unit heaters specify that the exhaust be sloped down so any condesate runs out the exhaust.I believe that adp and reznor are made by same manufacture.You may be able to find that in reznor instruction manuals also.this is only on the power vent models. These units can be exhausted up but you must install a tee and a drain.
Old 12-30-2006, 02:07 PM   #7
What happens to the HOT flue gasses that cant travel down, because the laws of physics tell us that hot air rises.?
Old 12-30-2006, 02:36 PM   #8
please note I did mention this is on a power vent model.ace do you disagree with this.I would be more than happy to post the adp instruction manuel on line for you.please correct me if I am wrong.I always want to give out correct information to help people.
Old 12-30-2006, 04:34 PM   #9
I am not making a attempt to discount your statement. I would love to see the instalation instructions though. I have never seen a manufacture that pourposely dumped acidic condensate out of a downward slopped vent pipe.
Old 12-30-2006, 06:41 PM   #10
well ace no problem.being a holiday weekend I cant get it till next week.but Idefinetly will do that for you.
Old 12-30-2006, 09:00 PM   #11
Is the www. shut down due to a holiday?
Old 12-31-2006, 10:17 PM   #12
Average Joe/ex-Navy IC3
gregzoll's Avatar
Personally, I do not see no reason as to not being able to run the venting down, then across the joists to an outside spot. I would just check with the HVAC contractor to make sure that the unit can allow for the venting to happen downwards, due to most you see have the vent pipes running up & then out the side to a outdoor point.
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Furnace venting questions Mastiff HVAC 9 12-05-2012 06:51 PM
New High Efficiency Furnace Problem Buster 567 HVAC 8 12-13-2010 09:36 PM
Options for venting 90+ furnace RM575 HVAC 2 06-17-2007 11:32 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
