Venting Help Lennox Slp98 70,000 Propane - HVAC - DIY Chatroom Home Improvement Forum
Old 02-28-2011, 08:47 AM   #1
venting help lennox slp98 70,000 propane
venting intake/exhaust for lennox slp98v 70k has 2" fittings on furnace
I'll be running hopefully just a 45 and a 90 about 6 ft then 16 ft out.
manual specs for 2 or 2 1/2 or 3inch. Any advantage to sizing one vs the
other, ie capacity/flow 3" (bigger better) or 2" better as smaller btu not
venting great distance?
dgdrx is offline   Reply With Quote
Old 02-28-2011, 01:10 PM   #2
Rewards Points: 380
Typically you would want to pick the vent sizing that is as small as possible that will fit into the venting table in the installation manual. The bigger the venting pipe the more expensive it is. It won't make any difference on performance and will sometimes hurt the longevity of the venting motor if the vent sizing is too large. Be sure to follow the instructions as to grade of venting pipe and support distances between hangers etc.
I beleive you should be able to use the 2" without an issue on a 70K model and only 25 feet of pipe, but I am not familiar with that exact model #.
HVACDave is offline   Reply With Quote
Old 02-28-2011, 01:58 PM   #3
An old Tradesmen
Rewards Points: 7,330
I wouldn't cut the flue/intake size close on that furnace. And make sure you install a drip tee in the flue.
There are a few bugs in that mod furnace.
Old 02-28-2011, 05:50 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 2,240
2" is best. You can go 86 feet with 2". If you live at an altitude over 7500 feet then you can go 61 feet with 2". That furnace has a huge tolerance for venting. Oversizing would not be good as it may have a hard time calibrating the pressure switches. We don't install drip tees in the flue of that unit. York and Rheem seem to want/like that but not required with Lennox. Are you a Lennox dealer or where did you get it from. Lennox usually does not sell those unless you are trained with them. The bugs are minor and have been corrected (new burner cover) and another technical issue.
Old 02-28-2011, 05:57 PM   #5
2" is what you want. Make sure you read and follow the condensate instructions or you will have pressure switch issues.
Old 03-01-2011, 04:31 AM   #6
An old Tradesmen
You haven't had the problem of excess condensate locking them out yet?
Old 03-01-2011, 05:26 AM   #7
Hvac Pro
yuri's Avatar
As long as they are sloped 1/2" to the front and 1/2" to the left if the trap is on the left side then that problem is not a problem. They re-designed the collector box to deal with that also.
Old 03-01-2011, 05:15 PM   #8
An old Tradesmen
I thought I heard that the redesign wasn't working as good as it was suppose to.
Old 03-01-2011, 05:26 PM   #9
Hvac Pro
yuri's Avatar
We have sold about a hundred of them since last fall. Most install manuals of all brands recommend the furnace be sloped forward. That unit drains great to the right side but if vented to the left needs a bit of slope. Has to do with the speed/rate that the condensate drains out of the secondary coil on high fire. Have not had any problems now that our installers know about it. Had to go shim up about a dozen of the others we installed.
Propane Mower Conversion homerb Green Home Improvement 21 03-16-2016 04:42 PM
Venting a sink pump WillK Plumbing 2 12-26-2010 01:21 PM
gas (propane) cooktop off a BBQ tank pstock Appliances 0 06-26-2010 09:21 AM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 06:37 PM
Propane hot water heater venting Makr Plumbing 7 12-13-2009 03:32 PM
