Venting Gas Rangetop - HVAC - DIY Chatroom Home Improvement Forum
Old 02-26-2009, 11:05 PM   #1
Cool
venting gas rangetop
We are embarking on a total kitchen remodel, and want to switch from a JennAire electric downdraft range to a duel fuel range (LP on rangetop, electric oven). The range will be installed in a penninsula. We don't really want an overhead hood if possible, and there is an outside wall about 5' from the range. We were considering putting in a remote blower near the outside wall, and then ducting to a vent behind the range top. Will this be enough suction? There is a bar with seating just behind the range, which makes installation of a large blower not possible. Any ideas? Are we doomed to an overhead hood? If so, what is the maximum distance (minimum view obstruction) that a hood can be from the range and still function well.
TDC3 is offline   Reply With Quote
Old 02-28-2009, 09:30 AM   #2
Rewards Points: 502
My brother had his kitchen remodeled and they put a high suction system in the peninsula that worked extremely well. You pushed a button and it came up out of the counter behind the range and when done retracted. Was a super clean isntall and worked extremely well. I'll see if I can find out the name of the product they used.
It was a unit by KitchenAid.
http://www.kitchenaid.com/flash.cmd?/#/category/290/
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Venting ponch37300 Plumbing 41 02-23-2013 11:37 PM
Furnace venting questions Mastiff HVAC 9 12-05-2012 06:51 PM
venting metal roof for attic conversion nelsonC Roofing/Siding 14 01-21-2010 03:32 AM
Blocked Attic Soffit Vents on North Side - How to Improve Venting Jes Roofing/Siding 5 05-06-2008 10:35 AM
Venting TonyD Plumbing 11 01-18-2007 07:31 PM
