Venting Furnace & Water Heater Together - HVAC - DIY Chatroom Home Improvement Forum
Old 04-04-2011, 02:03 PM   #1
venting furnace & water heater together
can a gas furnace and gas hot water heater (with power exhaust fan) use the same exhaust pvc pipe to vent to the outside of the house?
chams684 is offline   Reply With Quote
Old 04-04-2011, 02:19 PM   #2
Rewards Points: 380
Each appliance will need to be vented separately. If not, your inspector or insurance company will likely eat you alive. I don't know of any appliances in the direct vent catagory that will allow twinning of the vent system.
HVACDave is offline   Reply With Quote
Old 04-04-2011, 03:32 PM   #3
An old Tradesmen
Rewards Points: 7,270
Must be separate pipes.
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
gas hot water tank venting in chimney w no furnace... dbldee20 HVAC 5 02-25-2011 08:21 AM
gas fireplace with same vent as furnace & water heater? Van3 HVAC 0 01-30-2011 04:21 PM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 10:43 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
