Venting A Furnace (Creatively)... - HVAC - DIY Chatroom Home Improvement Forum
Old 09-26-2009, 10:59 AM   #1
Venting a Furnace (Creatively)...
This is my first post and I would really appreciate your support. I am installing a new AC Unit and Furnace. Unfortunately, my previous unit vented through the chimney while at the same time the AC and Furnace duct work also goes throught the same chimney. I believe this is illegal. But if it is possible I would like to keep the duct work in the chimney and find a way to vent the furnace somewhere else. Is it possible to vent the furnace out the wall? Any other ideas?
Thanks,
Joe in Baltimore
(FYI-This is a historic row house in Fells Point, circa 1890)
joeamundsen is offline   Reply With Quote
Old 09-26-2009, 11:50 AM   #2
An old Tradesmen
Rewards Points: 7,414
Then you'll need approval from the historical society to side wall vent it.
It will require a power vent if its an 80% furnace.
If its a 90%+ then it can be direct vented out the wall, if you have the clearances.
What efficiency furnace is it.
Old 09-26-2009, 01:10 PM   #3
I haven't purchased the furnace yet. But, if it is true that I can vent through the wall with a 90% efficient furnace I would go that way.
Thanks for the reply!
Tags
ductwork , furnace repair
Furnace venting questions Mastiff HVAC 9 12-05-2012 05:51 PM
High efficiency furnace venting Mnrunner HVAC 14 01-18-2009 09:25 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Options for venting 90+ furnace RM575 HVAC 2 06-17-2007 10:32 PM
