Venting Dryer Through Existing Foundation Vent - HVAC - DIY Chatroom Home Improvement Forum
Old 01-11-2017, 02:59 PM   #1
Rewards Points: 308
Venting Dryer through Existing Foundation Vent
Our house was built in the 80s, and like many homes built in the time, the dryer vents directly to the crawl space. We're in the process of getting this done, but have a couple of questions. On the wall where it would be most feasible to vent, there is an existing crawl space vent not 6" from where we would place the dryer vent.
Would it be an issue to direct the dryer vent through the existing vent? And if so, what would be the best way to do this? Trying to avoid drilling through a layer of block and brick for the dryer vent. Thanks in advance.
smokey847 is offline   Reply With Quote
Old 01-11-2017, 03:31 PM   #2
Rewards Points: 1,250
Re: Venting Dryer through Existing Foundation Vent
We can't see what your present crawl vent looks like but possibly you could retain the frame if there is one and replace the screen with something an outdoor style vent would attach to. Possibly pressure treated wood painted.
Old 01-11-2017, 04:48 PM   #3
Rewards Points: 308
It's trimmed out in this piece.
I would guess it to be 6" tall and 10" wide.
Old 01-15-2017, 10:01 PM   #4
Registered User
Rewards Points: 5,514
You could not use the screening in that vent as dryers are not allowed any screen anywhere (or even screws sticking in the smooth metal ducting), other than in the unit. Maybe you could use part of the existing vent for dryer, IF local code allows- closing the other 1/2 off- if you meet foundation minimums for ventilation without that one... not likely, IMO.
Gary
PS. and it not closer than 3' to a house opening; pp. 7/9; http://www.codecheck.com/cc/ccimages...6th_Sample.pdf
Dryer vent location close to DWV vent WillK General DIY Discussions 4 10-05-2015 11:09 AM
question about right angle drilling into existing foundation for new sillplate Pawl Building & Construction 15 06-04-2013 03:02 PM
New Roof marknok Roofing/Siding 4 08-06-2011 11:41 AM
Dryer Vent type? cbzdel General DIY Discussions 6 06-08-2010 08:17 PM
Help, how & where can I vent a 2nd floor dryer? jaes Remodeling 2 06-28-2008 10:03 AM
