Venting Bathroom Fan Via Soffit - HVAC - DIY Chatroom Home Improvement Forum
Old 07-29-2012, 04:32 PM   #1
Rewards Points: 1,010
Venting bathroom fan via soffit
I recently started feeling hot attic air pouring into my bathroom through the fan. I climbed in the attic and found the flexible duct had disconnected from the fan, allowing attic air to pour right in. I also found the air flap in the fan didn't close off well, allowing the air to pour in. And I also found the exhaust end of the flex duct was just laying in the attic.
I fixed the flap so it would close and reconnected the flex duct to the fan. But now I'm wondering where to connect the outlet end of the flex duct. I can vent the exhaust duct through the soffit, but I decided to read up before doing this.
From what I've read some say it's fine, others say it's a bad idea as the warm, moist air from the bathroom can come out and then go right back into the attic via the soffit. But I question that argument because the outdoor air on a hot, humid day can also enter through the soffit, so what is the difference?
So asking you all - what are your opinions on running a bathroom vent out the soffit?
spaceman spif is offline   Reply With Quote
Old 07-29-2012, 04:51 PM   #2
Forgot to mention that there is already a ~3" diameter hole cut in the soffit where the exhaust duct could connect. Looks like the hole was cut for a pipe that is no longer there.
So if running through the soffit is okay, a good bit of the work is already done. But if it's not okay, I need to permanently cover that hole with something else...because the birds and squirrels sure do like my attic!
Old 07-29-2012, 04:54 PM   #3
I love your screen name, Spif!
It's okay to vent through the soffit. They make special vent terminations for this purpose that will look a whole lot better than just sticking the pipe through the hole.
TopTechnician is offline   Reply With Quote
Old 07-29-2012, 04:57 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Soffit is okay, but you need a vent cap like below...
I would highly recommend using insulated flexible duct to your fan as well. This will help tremendously...
ideas of venting a bathroom fan in attic david szela Building & Construction 10 01-14-2012 07:06 AM
Plumbing - Venting Bathroom - Please HELP garysacco Plumbing 4 12-09-2011 10:31 AM
Bathroom Venting on Septic System edro Plumbing 2 01-03-2011 08:41 AM
Venting a bathroom Cossack Plumbing 10 06-27-2010 04:07 PM
Could lack of soffit venting increase indoor negative air pressure? creamaster Roofing/Siding 1 03-07-2009 02:27 PM
