Ventilation Options For Finished Basement - HVAC - DIY Chatroom Home Improvement Forum
Old 11-14-2011, 12:53 PM   #1
Ventilation Options for Finished Basement
I am about to begin finishing my basement with three main rooms:
18'x13' Utility/Workroom
11'x16' Bedroom
11'x23' Den
The bedroom will have a casement egress window, the den currently has two small vent windows (and a walk-up door), and the utility room currently has no windows. The egress window will likely come close to, but not meet the ventilation requirements of 4% of the floor area, and the vent windows in the den will not come anywhere near the 4%. What are my options for increasing the ventilation? The house has a gas boiler and hot-water baseboard heat, and no a/c or other ventilation system. Also, with a 90,000 BTU boiler and a 40,000 BTU hot water heater, I am planning on using a louvered door on the utility room to satisfy the combustion air requirement. All of this assumes that I am able to add another zone to the current boiler to heat the basement.
Thanks for your help.
bugman61 is offline   Reply With Quote
Old 11-14-2011, 05:22 PM   #2
An old Tradesmen
Rewards Points: 8,164
ERV, is probably best bet.
Old 11-15-2011, 12:21 PM   #3
After going through the code some more, it seems that this may exempt my project:
http://publicecodes.citation.com/ico...001_par002.htm
Does anyone know if this is the case? I of course will talk about it with the local buidling inspectors office, but I'm just trying to narrow down the project a bit.
Old 11-15-2011, 05:22 PM   #4
An old Tradesmen
I think you'll find that it applies if your adding windows to an already constructed habitat area that wasn't built before the code. Not to a new habitat area.
Best bet, is to contact your local code/building agency.
Need advice on options for basement plumbing pete0403 Plumbing 5 07-04-2011 08:18 PM
Concrete Basement Floor Insulating options McSweny1103 Insulation 7 03-08-2011 05:24 PM
Need HELP swapping a Vision pro 8320u1008 to an IAQ one N01B4ME HVAC 161 01-10-2011 02:30 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 12:23 PM
