Ventilating Closet With COndenser Dryer - Would A Fan Help The Dryer's Performance? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-06-2012, 12:53 PM   #1
Ventilating closet with COndenser dryer - would a fan help the dryer's performance?
Hi!
This is my first post - so please be patient.
I have a stackable washer/dryer, with a condenser dryer. The dryer does well - it take extra time to dry, but does the job.
I was wondering if it would help the dryer operate better if I were to
(a) Install a small ceiling fan in the closet or
(b) put a regular pedestal fan on top of the dryer.
This would blow out the heat that is rising to the top of the closet. Not sure if this would help the dryer's operation, however.
214Green is offline   Reply With Quote
Old 09-06-2012, 01:01 PM   #2
Rewards Points: 13,300
Nope not going to help.
Yours works by condencing the hot moist air with cold water running through a sealed coil, works just like a stil.
Notice how your electric and water bills shot up when you started use that type washer and dryer?
What I would concider is changing the door to a louvered door or adding a bathroom fan with a line to the outside.
Old 09-06-2012, 05:52 PM   #3
An old Tradesmen
Rewards Points: 6,550
Not all condensing driers use water to cool them. His may only use the surrounding air, in which case a fan would help a lot.
Old 09-06-2012, 06:11 PM   #4
Did you miss this part?
"I have a stackable washer/dryer, with a condenser dryer. The dryer does well - it take extra time to dry, but does the job"
Old 09-06-2012, 07:11 PM   #5
An old Tradesmen
Again, not all condenser driers use water to cool the drier air. they all need a drain, but not all of them use water from the house.
from his description of the room/closet/alcove becoming hot, it doesn't sound like his model uses tap water to cool the heat exchanger.
If it did, then the area shouldn't be hot.
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 02:10 PM
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 12:00 PM
installing dryer in old water heater closet? darsunt Appliances 9 11-11-2011 08:16 PM
Help with Electric 240v for a Dryer Sunshine807 Electrical 17 10-21-2011 11:35 AM
Condenser dryer or filter location?? viper HVAC 11 09-14-2010 04:01 PM
