-   -   Ventilating closet with COndenser dryer - would a fan help the dryer's performance? (http://www.diychatroom.com/f17/ventilating-closet-condenser-dryer-would-fan-help-dryers-performance-156027/)
214Green 09-06-2012 11:53 AM
Hi!
This is my first post - so please be patient.
I have a stackable washer/dryer, with a condenser dryer. The dryer does well - it take extra time to dry, but does the job.
I was wondering if it would help the dryer operate better if I were to
(a) Install a small ceiling fan in the closet or
(b) put a regular pedestal fan on top of the dryer.
This would blow out the heat that is rising to the top of the closet. Not sure if this would help the dryer's operation, however.
joecaption 09-06-2012 12:01 PM
Nope not going to help.
Yours works by condencing the hot moist air with cold water running through a sealed coil, works just like a stil.
Notice how your electric and water bills shot up when you started use that type washer and dryer?
What I would concider is changing the door to a louvered door or adding a bathroom fan with a line to the outside.
beenthere 09-06-2012 04:52 PM
Not all condensing driers use water to cool them. His may only use the surrounding air, in which case a fan would help a lot.
joecaption 09-06-2012 05:11 PM
Did you miss this part?
"I have a stackable washer/dryer, with a condenser dryer. The dryer does well - it take extra time to dry, but does the job"
beenthere 09-06-2012 06:11 PM
Again, not all condenser driers use water to cool the drier air. they all need a drain, but not all of them use water from the house.
from his description of the room/closet/alcove becoming hot, it doesn't sound like his model uses tap water to cool the heat exchanger.
If it did, then the area shouldn't be hot.
