Old 01-22-2009, 01:58 PM   #1
vent sucks cool air instead of blow heat
two bedrooms in my house have developed the same problem. the return in each sucks are normally, but additionally the vents don't blow heat, instead suck air in a little. not as much as the return though. all my "output" vents at the furnace are connected. all other vents connected to furnace are ok.
thanks
wayneled86 is offline   Reply With Quote
Old 01-22-2009, 07:09 PM   #2
Check the air filter and evaporator coil to make sure they're clean.
SKIP4661 is offline   Reply With Quote
Old 01-25-2009, 03:11 PM   #3
thanks. it's only two vents though the others are great.
Old 01-25-2009, 11:10 PM   #4
JohnH1's Avatar
Something had to have changed in the system like someone changed some damper settings. Try closing down on some dampers or registers to increase static pressure on the duct system. This should help. Make sure you mark the oridginal damper settings so you can always put back as it oridginally was.
JohnH1 is offline   Reply With Quote
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 04:57 PM
heat vent locations? ponch37300 HVAC 9 02-19-2008 12:04 PM
Electical Wire Near Heat Vent Glimmerman911 Electrical 2 12-18-2007 04:58 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
