Vent Size For 40 Gal Gas Water Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 10-19-2011, 02:39 PM   #1
Rewards Points: 1,062
Question
vent size for 40 gal gas water heater
my water heater has a 3" vent opening on top but i would like to use 4" vents from the heater to where it enters the vertical chimney part (which is a sleeve 6" inside the shaft) to enable future scaling up to maybe a 60 gal heater. i was wondering if using a size bigger vent would be OK for the time being.
thanks
here is the heater:
http://www.lowes.com/webapp/wcs/stor...AID=1023733042
Old 10-19-2011, 04:18 PM   #2
Rewards Points: 6,652
Would be easier to just go with a power vent water heater.
Old 10-19-2011, 04:30 PM   #3
An old Tradesmen
Rewards Points: 6,498
Nope. Just use the 3", and then when you get the larger water hear, run a new pipe of the proper size.
Old 10-19-2011, 04:40 PM   #4
Question
but the pipe runs through a ceiling, i would have to tear off drywall. what's wrong with using a size bigger vent?
cause once it goes into the chimney shaft, it will be bigger anyway (6"). so what's the problem with being less bigger on its way there? there is about 10' of sloped horizontal piping between the appliance and the chimney.
also, this is type B venting.
e.g. i could use a 3" pipe to go directly out of the appliance to the ceiling where it makes the first bend. but then there it would meet a 3->4" adapter. does this sound OK?
Old 10-19-2011, 05:28 PM   #5
An old Tradesmen
6" vertical is ok. But a larger size horizontal will slow the flue gasses and give them too much time to cool. Specially the pilot flame. And generally cause poor draft problems, and condensate issues.
The max size chimney a 3" vent hood may be connect to is 49 sq in of area/cross section. a 6" round is only 28 sq in so thats ok.
Is the B vent coming through the ceiling all vertical, or is any of it horizontal.
Old 10-19-2011, 05:33 PM   #6
there is about 10' horizontal between where it enters the ceiling above the appliance and the chimney. then about 16' vertical.
Old 10-19-2011, 05:35 PM   #7
An old Tradesmen
And you have 1" clearance for the B vent in this area above the ceiling?
Old 10-19-2011, 05:39 PM   #8
absolutely, i actually have something like a sub-ceiling through which the pipe runs and there is AT LEAST 1" clearance everywhere around the pipe.
Old 10-19-2011, 05:53 PM   #9
30 year tech
hvac122's Avatar
Believe it or not here in Lincoln NE it is against code to run anything smaller than 4" off of a water heater. We must use a 3-4" increased right off the diverter or as quickly as possible.
Inspectors know all. Lol
hvac122 is offline   Reply With Quote
Old 10-19-2011, 06:26 PM   #10
newtech's Avatar
Rewards Points: 164
Most building codes require 4-inch flue pipes on water heaters.
I know that we have to here.
newtech is offline   Reply With Quote
Old 10-19-2011, 07:15 PM   #11
An old Tradesmen
Not here. 3" if its a 3" breech.
Tags
vent , water heater
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 11:36 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
