Vent Filters - HVAC - DIY Chatroom Home Improvement Forum
Old 01-01-2016, 05:19 PM   #1
Rewards Points: 154
Vent filters
I know these things are not typically recommend but I have a problem. The flex duct needs to be replaced and we won't be able to do so for at least a couple weeks. They've been in bad shape a while but I didn't realize the extent. Last winter or possibly before that it seems some rodents decided to chew holes throughout the inner lining (the outsides are fine) so I'm worried fiberglass is blowing in the house. In the interim, can I use the filters on all of them? We have one of the most expensive filtrete filters on the return.
boondocks95 is offline   Reply With Quote
Old 01-01-2016, 05:32 PM   #2
Rewards Points: 7,652
try them if you'd like.
on the supply side fiberglass won't get into the air stream, air will just leak out of he duct.
My Backround FIY: I am not in the business of any trade or topic I give advise on. I have some have formal education in HVAC + some DIY experience. Theory is not a substitute for experience.
user_12345a is offline   Reply With Quote
Old 01-01-2016, 06:40 PM   #3
Rewards Points: 3,830
Be careful using expensive 1" pleated filters on the return. They can block airflow and cause equipment malfunction or even cause damage.
roughneck is online now   Reply With Quote
Old 01-02-2016, 02:10 PM   #4
Rewards Points: 154
I'm confused as to how the fiberglass won't leak into the supply? The holes are on the INSIDE right below the vents and I can see pink in almost all of them. The holes are not on the outside when inspecting from the crawlspace.
See pic.
plumbing vent boilermaker27 Plumbing 5 09-26-2013 07:37 PM
Installing a gable vent..from *inside* the attic steveKane Building & Construction 8 12-09-2012 02:45 PM
Vent Suggestions ddawg16 Plumbing 5 03-13-2012 02:36 PM
New Roof marknok Roofing/Siding 4 08-06-2011 11:41 AM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 06:34 PM
