Vent Covers - HVAC - DIY Chatroom Home Improvement Forum
Old 04-22-2013, 11:58 PM   #1
Rewards Points: 87
Vent covers
I just saw this setup for alternative vent covers: http://www.remodelista.com/posts/arc...e-heating-vent
And as I am in the middle of a re-model was wondering what would be some potential problems with this setup and what I would need to consider if I did something similar.
hellonoko is offline   Reply With Quote
Old 04-23-2013, 08:06 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,238
- may whistle
- will get dirty and be hard to clean the holes
-may slow down the flow and throw pattern of the air and coverage it makes in the room/circulation and comfort
-that idea is good for convection heaters/boiler radiators
Old 04-23-2013, 11:01 AM   #3
Special User
Rewards Points: 1,230
Originally Posted by yuri View Post
- may whistle
I'd suggest router-ing the holes (both front- and back-side) with a roundover bit and painting with semi-gloss paint.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 04-23-2013, 11:33 AM   #4
Rewards Points: 87
Thanks for the notes.
If I do it I will make it routed, removable, and research the proper airflow so I can match that with amount/size of holes.
Old 04-23-2013, 06:31 PM   #5
Rewards Points: 79
These would probably work for returns if they are big enough but for supply vents I agree with Yuri with concerns about round holes distributing the air correctly.
Ebierley is offline   Reply With Quote
Old 04-23-2013, 06:59 PM   #6
Hvac Pro
yuri's Avatar
Yeah, if you carefully look at a register there is some engineering involved in the shape and angle of the fins etc. Designed to throw the air far so that it sweeps downward and provides a circle/circulation effect. Those holes may prevent/eliminate that effect.
Tags
vent
Direct Vent Water Heater Question kc27 Plumbing 2 02-12-2014 01:39 PM
Concentric Vent Retrofit benchlands Plumbing 4 12-18-2012 04:48 PM
Bathroom Vent Covers dkomor Kitchen & Bath Remodeling 1 05-01-2011 07:37 AM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 05:17 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 06:34 PM
