Old 09-03-2004, 05:47 PM   #1
Unregistered
Guest
Posts: n/a
variable speed motor for hvac
can anybody give pros / con vatiable speed motors for a gas furnace
Old 09-03-2004, 07:49 PM   #2
Unregistered
Guest
Posts: n/a
They are quiet and energy efficient. They help overcome some of the problems with restrictive ductsystems and high static pressures. Good for maintaining proper humidity levels in the cooling cycle and helps keep temps more even in both the heating and cooling cycles (when used with fan on). CFM's can be custom tailored to your system and your comfort levels. Unlike first generation variable speed motors, control head on motor is replaceable by itself now instead of needing a whole motor assembly.
Old 01-14-2005, 12:58 PM   #3
Talking
Pros: Saves fuel, saves on electricity costs, quieter, usually can tailor blower speeds and cycle times.
Cons: costs a bit more than other furnaces.
Check with your electric or gas company to see if they offer rebates on such equipment.
Chandler is offline   Reply With Quote
Are variable speed HVAC units worth the $$$? Jemo HVAC 9 05-07-2011 05:10 PM
Heat Pump blower speed? ktkelly HVAC 1 07-18-2007 11:01 PM
Slowing fan motor speed in air handler Manuel6 HVAC 7 04-17-2007 10:01 AM
Fan speed low... ktkelly HVAC 2 04-11-2007 08:34 PM
Speed control of ceiling fan pjpjpjpj Electrical 7 03-19-2007 04:13 PM
