-   -   Are variable speed HVAC units worth the $$$? (http://www.diychatroom.com/f17/variable-speed-hvac-units-worth-7574/)
Jemo 04-04-2007 09:43 PM
I'm about to replace a 2.5 ton unit in our house and the guy was saying what an improvement the variable speed air handlers are over the 1 and 2 speed units from the past.
They're about $1k more. Is it worth the extra cost?
handy man88 04-05-2007 07:40 AM
Yes, it's definitely worth the extra cost if you plan on staying in the house for awhile. You can easily recoup that cost in energy savings within 3-5 years.
Jemo 04-05-2007 07:53 AM
Thanks. Yes, we definitely plan to stay for a long time.
I forgot to mention though that the main area of the house is cooled and heated by a 5 ton unit that is about 5 years old. No reason to replace it because it works fine so I didn't know if a small variable speed unit matched with a larger single speed unit would be worth the extra cost.
handy man88 04-05-2007 11:51 AM
Ok, where is the variable speed going? I think a variable speed would be better off for the larger area unit that heats/cools a larger area, but that's moot now.
Jemo 04-05-2007 12:02 PM
The small unit is for the 3 bedrooms. The large unit is for the living area, kitchen, den, etc.
handy man88 04-05-2007 01:14 PM
Might not be worth it. I mean, how much time do you spend in those bedrooms? Probably not a lot of time while awake. During the cold season, it's recommended to turn down the heat when sleeping, and for hot season, it's generally cooler at night.
I would only make that investment in an area that's a living area where people spend most of their awake time, and that's where the larger unit is currently being used.
rnault 05-07-2011 10:54 AM
I installed a Carrier Infinity, (4) zone system, 2 - speed condenser and variable speed air handler. It makes a positive difference on the electric bill each month. Go for it!!
beenthere 05-07-2011 12:36 PM
Nice system.
But 4 years late for the OP.
yuri 05-07-2011 01:09 PM
2 speed/stage condensor is really well suited to a zoning system with ECM variable speed fan/airhandler. The Lennox Harrmony 3 I installed has the ability for the zoning panel to control the ECM motor speed and firing rate for a 2 or 3 stage and now modulating Lennox furnace according to how many zones are open. VERY sweet stuff. Need a 2 stage AC as it can handle several zones closed (unload) a lot better than a 1 stage. Should save him a LOT of electricity $$ as it can de-humidify much better than a basic system.
handy man88 05-07-2011 04:10 PM
How long do you estimate it will take for the savings in the electric bill to catch up to the extra cost of the variable speed option?
