Variable Speed Blower - HVAC - DIY Chatroom Home Improvement Forum
Old 01-10-2011, 05:30 PM   #1
I just bought a house that has a Goodman ARUF036-00A-1A Airhandler that is only about 5 years old. My question is can I install a variable speed blower motor in this unit to have constant, low CFM circulation?
New here and any help would bw appreciated!
THANKS!!!
trbboy is offline   Reply With Quote
Old 01-10-2011, 05:56 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,422
You cannot put a variable speed ECM high efficiency motor in as it needs a special programmed circuit board that only the manufacturers can provide to control the speed. You can get a 4 speed ECM energy efficient motor but it may cost you $400-500 and would take forever to pay for itself.
Old 01-10-2011, 06:00 PM   #3
Experienced
Jackofall1's Avatar
Are you trying to just circulate air 24/7 or heated air 24/7.
You can run a circulation fan motor continuously on a low speed as long as it kicks up to the correct speed when there is a call for heat.
Old 01-10-2011, 06:19 PM   #4
Thanks for the quick answers.
I just want to circulate the air in the house. My main source of heat is a wood stove in the main room. The circulation will help balance the heat as well as filter the air. I can run the fan on maunal but the speed is too high and will cool off the air. Have been researching the ECM and EchoTech motors but figured I would also have to replace the circuit board but wasn't sure if I could even do that without replacing the air handler. Anyone have any other suggestions?
Thanks again for the quick answers, Trbboy
Old 01-10-2011, 06:29 PM   #5
Hvac Pro
yuri's Avatar
The Ecotech may have a lower than average low speed so it is not as drafty. Not sure what the RPM is but you may be able to find out. We sell them as an upgrade to furnaces (my sales guys do with ACs). May be worth it if you can get one at a reasonable price. The true Variable speed ECMs only come with new units.
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 05:39 PM
Variable speed Blower konqwest HVAC 4 12-01-2009 05:45 AM
variable speed blower satishprabhu HVAC 1 07-01-2009 12:32 PM
variable speed or single speed air handler bchlady HVAC 2 06-05-2008 09:40 PM
Variable Speed Blower qnzkrew HVAC 2 01-03-2008 07:14 AM
