Old 01-31-2013, 12:02 AM   #1
variable speed blower
blower does not work at all ? HELP PLEASE Wife is about to go to a hotel...lol
capone55 is offline   Reply With Quote
Old 01-31-2013, 12:05 AM   #2
Got a meter, and know how to use it?
Old 01-31-2013, 12:09 AM   #3
i know how to use a meter
Old 01-31-2013, 12:21 AM   #4
Moderator
Well, I'm pretty sure you need to check for power to the unit in question with the meter, though I'm not in HVAC. A pro should be along shortly or for sure; in the morning. Please keep in mind our forum rules found at page bottom under "Privacy statement" or "Terms...."
Sorry I couldn't help you more. Gary
Clothes taking longer to dry?
Old 01-31-2013, 12:25 AM   #5
Moderator
You can also try the white "search" box at the top of every page, eg.; http://www.diychatroom.com/search.php?searchid=3797970
Click on my link for titles, hold mouse cursor over title to pre-read a little...
Gary
Old 01-31-2013, 12:25 AM   #6
it is getting power ...i narrowed it down to ECM or circuit board but not sure of the order in which they kick in?
Old 01-31-2013, 12:27 AM   #7
it is a AMANA Furnace...model # guva 070bx40
Old 01-31-2013, 02:51 AM   #8
how
I believe you should check if this model is available with a separate motor and end casing. Not all are available as separate components which would then mean the diagnosis of one or the other is a moot point. You are now in Pro territory....
You said that the motor was OK but
Did the motor turn easily enough? Ball bearings OK?
Ohm each motor winding to the case for OL.
Olm each winding to each other. Should measure within 5 to 20 olms and within 10% of each other.
If all is OK, the motor is probably OK.
After unplugging the 120V motor supply and letting it drain for 5 minutes so you don't get shocked, unbolt the end casing.
Does the motor spin differently when the motor is plugged into the end casing as opposed to when its unplugged from it? If so the end casing has a short and is shot.
The only repairable part within that I know of would be the thermistor if it looks burnt, disconnected or swollen. That can be ordered from an electronics supply house or tracked down through Google and soldered in to replace the old one.. It will be a 1 olm 20 Amp or a 1 olm 30 amp depending on the size of the motor. The OEM's don't help here with thermistors. Beyond that, its ordering a new identical end housing if it's available, and for big $$$.
how is offline   Reply With Quote
Old 01-31-2013, 05:20 AM   #9
An old Tradesmen
Probably need this repair kit.
http://www.getzebra.com/proddetail.asp?prod=VZREP
The Following 2 Users Say Thank You to beenthere For This Useful Post:
how (01-31-2013)
variable speed trane blower motor afn63537 HVAC 25 01-13-2013 06:31 PM
Replacing HVAC blower motor with a variable speed fan bkuritz HVAC 2 06-13-2011 12:33 AM
Variable Speed Blower trbboy HVAC 4 01-10-2011 06:29 PM
Variable speed Blower konqwest HVAC 4 12-01-2009 05:45 AM
variable speed blower satishprabhu HVAC 1 07-01-2009 12:32 PM
