Old 07-22-2009, 11:36 PM   #1
Variable Speed Air HAndler
I just got a new HVAC unit installed and my thermostat is jumping up and down in temperature. So far it has been on for about 6 hrs turning off about three times and quickly turning back on. Is this normal for a new system, is the thermostat not functionin correctly, not enough refrigerant or a bad installation? Also, what is the difference between stage 1 and 2 on the air handler? One more thing, what percentage should the fan be in?
rguerra is offline   Reply With Quote
Old 07-22-2009, 11:52 PM   #2
hvaclover's Avatar
Have your installer check the stat set up. He should have explained all that to you. Did he install a new thermostat?\\
Run time is with in the ball park having just started up.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Are variable speed HVAC units worth the $$$? Jemo HVAC 9 05-07-2011 05:10 PM
variable speed blower satishprabhu HVAC 1 07-01-2009 12:32 PM
Variable Speed Trim CFM Adjust Mode mjbxx HVAC 3 03-04-2009 06:19 AM
variable speed or single speed air handler bchlady HVAC 2 06-05-2008 09:40 PM
Slowing fan motor speed in air handler Manuel6 HVAC 7 04-17-2007 10:01 AM
