Variable Motor - HVAC - DIY Chatroom Home Improvement Forum
Old 12-08-2009, 11:22 AM   #1
variable motor
anybody's opninion on how cost efficient it would it be to add the variable motor to a new high efficiency furnace (electricity savings?)
darylw is offline   Reply With Quote
Old 12-08-2009, 11:24 AM   #2
An old Tradesmen
Rewards Points: 7,776
Add on to an existing furnace, or gat a new furnace with a VS blower?
Old 12-08-2009, 12:38 PM   #3
add on to anew furnace to be installed -lennox-71
Old 12-08-2009, 04:39 PM   #4
An old Tradesmen
Adding on to a furnace. You won't get a ROI unless you run the blower 24/7, And your duct work is sized right.
Getting a furnace that has a VS blower, you'll get a small return, even if you don't run the blower 24/7.
If your talking about the Lennox MOD, as far as I know it doesn't come in a Standard PSC blower version.
Old 12-08-2009, 07:01 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 96
Only 1 type of G71 and it has a ECM variable speed motor. No need to add it on. Great furnace.
Oiling Trane XB1000 AC Fan Motor Build HVAC 5 06-19-2009 04:05 PM
Motor control wiring problem dgr68 Electrical 8 01-04-2009 05:13 PM
Goodman motor availability NomadTrash HVAC 5 11-08-2008 11:01 AM
Replacing a Condenser Fan Motor thothtp HVAC 5 06-08-2008 06:30 PM
variable speed motor for hvac Unregistered HVAC 2 01-14-2005 11:58 AM
