Valve Near Pump On Hydronic Heat Boiler - HVAC - DIY Chatroom Home Improvement Forum
Old 12-17-2013, 08:21 PM   #1
Rewards Points: 1,062
valve near pump on hydronic heat boiler
Can anyone identify the purpose of this lever valve on this smallest of the three pipes going into the pump on my hydronic heat boiler?
Old 12-17-2013, 09:54 PM   #2
joed's Avatar
Rewards Points: 12,890
It's closed.
Could be the water feed to fill the boiler. Is it attached to main house water supply?
Can you take another picture from a bit further back.
Old 12-18-2013, 10:59 AM   #3
no, there is another valve for that.
i'm thinking it may be a drain valve for the pump
Old 12-18-2013, 11:49 AM   #4
Rewards Points: 282
I agree, makes sense. Maybe it's also used to get air out of the lines if you have to drain/refill boiler. Just a thought. Only thing, where does it drain to? Strange how it goes back into the boiler like that, must exit on the other side somewhere to a drain or bucket. Almost looks like some sort of bypass. Stay tuned, I'm sure someone here will identify it's purpose.
jmon is offline   Reply With Quote
Old 12-18-2013, 12:22 PM   #5
into the main drain flow of the rest of the appliance. because this piece of the system presents a flow trap that the main drain alone won't drain.
it's kind of hard to explain but it is somewhat equivalent to the bottom of a P trap that, if you wanted drained for some reason, you'd need to have a hole in the bottom of...
The Following User Says Thank You to amakarevic For This Useful Post:
jmon (12-18-2013)
Old 12-18-2013, 05:35 PM   #6
747
registered
747's Avatar
Rewards Points: 534
looks like a drain valve if replacing circulator pump
747 is offline   Reply With Quote
Old 12-18-2013, 06:02 PM   #7
DIY staff
Rewards Points: 7,174
Moved to 'HVAC'---Mike---
Old 12-18-2013, 06:04 PM   #8
DIY staff
A shot from further back might help---
Old 12-18-2013, 08:28 PM   #9
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,.... It sounds like yer sayin' there's a check-valve in the pump, 'n points beyond won't drain through,...
Bondo is online now   Reply With Quote
Old 12-18-2013, 08:29 PM   #10
An old Tradesmen
Rewards Points: 7,344
Looks like a boiler bypass. When adjusted properly it helps maintain proper delta temp across the boiler. Plus it allows the boiler flue passages to get above condensate temp quicker so the flues don't clog or have condensate dripping onto the burners.
Old 12-18-2013, 09:09 PM   #11
Rewards Points: 446
X2 what beenthere said.
Can you post a picture of the entire boiler? I'm just curious as that piping arrangement looks like a manufacturer's item/arrangement. Haven't seen this before.
old_squid is offline   Reply With Quote
Goodman heat pump - W2 wire to thermostat taxmantoo HVAC 12 07-18-2013 08:26 PM
Thermostat - Old Heat Pump to New Programmable AlexDIY HVAC 0 03-03-2013 08:17 PM
Heat Pump Crisis Part II Doc Holliday HVAC 58 12-07-2011 09:14 PM
Heat pump starts initially but will not come back on to maintain temps johnniebravo HVAC 53 11-22-2011 07:48 PM
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 05:38 AM
