Valve Above Expansion Tank Is Leaking - HVAC - DIY Chatroom Home Improvement Forum
Old 02-08-2014, 12:38 PM   #1
Valve above expansion tank is leaking
So I came home today and my garage smelled a little funny. I went and checked out the boiler and it was wet under m expansion tank. There is this tube shaped piece with a valve on top that is about the size of a tire stem valve. It looks like it leaking out of that. The screw on top was not tight but either way if I tightened it or not it still leaking a little. I did not leave it tight because it was not tight when I looked at it at first. It's not a nut but more like an aircap but with a hole it in. Please see pictures. So my concern is do I need someone to come fix this right away? Can I fix it myself? Why is it doing it? etc. The pressure on my boiler never goes over 20psi.
Here are some pictures
mjmccarthy85 is offline   Reply With Quote
Old 02-08-2014, 04:14 PM   #2
An old Tradesmen
Rewards Points: 7,794
Its an air vent. Dirt has gotten to it. You an replace it yourself. Need to reduce boiler pressure to zero to do it.
Old 02-08-2014, 05:45 PM   #3
Rewards Points: 1,668
Copied from OP #1 to read in its entirety.
SeniorSitizen is offline   Reply With Quote
Old 02-08-2014, 06:56 PM   #4
An old Tradesmen
And??
The Following User Says Thank You to beenthere For This Useful Post:
danpik (02-09-2014)
oil furnace expansion tank ? gwilkrrs HVAC 5 01-14-2014 05:35 PM
Toilet Still Leaking After Replacing Gasket, Bolts, Fill Valve, Flush Valve wheeee Plumbing 23 04-19-2013 03:49 PM
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 05:55 AM
Hot water tank relief valve leaking Lance45 Plumbing 7 04-21-2012 09:54 PM
Pressure relief leaking and expansion tank full themow HVAC 1 11-25-2009 04:49 PM
