Vacuum Gauge ? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-08-2012, 07:50 AM   #1
Rewards Points: 236
vacuum gauge ?
is there a inexpensive vacuum gauge that will read pressure in the ducts, and vacuum in the returns ?
i don't have an issue. but this is something i would be interested in knowing. i'm funny that way.
Fix'n it is offline   Reply With Quote
Old 12-08-2012, 09:15 AM   #2
An old Tradesmen
Rewards Points: 7,826
http://www.amazon.com/s/?ie=UTF8&key...l_40wxtjj3u9_b
http://inspectusa.com/manometer-anal...ce=google-base
Old 12-08-2012, 09:41 AM   #3
Rewards Points: 1,708
If you're looking for inexpensive and accurate, purchase a length of clear plastic tubing at your favorite hardware store and make a water manometer. A small amount of food coloring makes it easier for the old eyes to see . I also use mine to check PVC valve function on automobile engines .
Old 12-08-2012, 12:52 PM   #4
TTW
TTW's Avatar
I believe you can also use a gauge from a blood pressure cuff.
I think that would only give you pressure though.
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-08-2012, 12:58 PM   #5
TTW
TTW's Avatar
Something like this.
Of course, you don't need the balloon thing.
The Following User Says Thank You to TTW For This Useful Post:
jagans (12-08-2012)
Old 12-08-2012, 01:54 PM   #6
Something like that but I don't feel successful unless I've used duct tape to hold the two tubes side by side and maybe guess for anything under 2" differential, but graduate to a tape measure for longer distances. I'm poor and mine must double as a drip irrigation tube in the dry arid climate when not doing manometer duty so it doesn't get attached to anything.
I don't make wine.
Old 12-08-2012, 03:04 PM   #7
An old Tradesmen
The static pressure in any of your ducts will be less the 1". Hopefully less then .3", an inclined manometer works better then just a straight up and down one.
Old 12-08-2012, 08:11 PM   #8
Hello I'm new to this forums.
But with my pass experience a slant tube manometer or u-tube style will work..Hope i was able to help..
oncall is offline   Reply With Quote
Central vacuum issue omgwtf Appliances 6 10-14-2012 08:05 AM
transfer switch - wire gauge soma Electrical 14 12-03-2011 09:53 PM
value of 16 gauge sink over 18 gauge in residential home njanicen47 Plumbing 2 09-11-2010 02:53 PM
mixed gauge wire on 15 amp circuit GretaDIY Electrical 4 07-03-2010 03:20 PM
15 or 16 gauge nailer for larger MDF Crown Klawman Carpentry 2 11-10-2009 01:16 PM
