UV Light For HVAC System - HVAC - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 03:37 PM   #1
UV light for HVAC system
When wiring a UV light to the contacts of the fan so the uv only comes on while the fan cycles, will the UV light be less efficient and is there a warm up period for the UV light or is it a full illumination as soon as you give power to it.
Any help would be appreciated
Dennis gaddis is offline   Reply With Quote
Old 04-22-2012, 07:17 PM   #2
Rewards Points: 614
no warm up required.. does little when fan not running...uv light must only be on when fan is running.....
carmon is offline   Reply With Quote
Old 04-22-2012, 08:16 PM   #3
uv light
Thank you, I installed the light. It goes in rather easy.
Old 04-22-2012, 08:17 PM   #4
Rewards Points: 614
yes uv lights are quite easy..... enjoy it...
Old 04-22-2012, 10:24 PM   #5
sktn77a's Avatar
Rewards Points: 360
I thought UV lights primarily prevented mold from growing on the coil (vs doing anything to the air which is moving across them). If that's the case, I guess it is just a question of whether you want the light on all the time (?)
sktn77a is offline   Reply With Quote
Old 04-22-2012, 10:37 PM   #6
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
They're for overall air purification (of bacteria). Some do question their effectiveness and that's probably a whole other debate, but for the ease of install and low cost, it does not hurt anything.
Red Squirrel is online now   Reply With Quote
Old 04-22-2012, 10:38 PM   #7
Rewards Points: 614
uv lights do many things besides kill mold..... to many to describe.... google uv light you will be suprised
Looking for a special light switch for task lighting shazapple Electrical 3 01-02-2012 10:39 PM
3 and 4 way switches - power to first light mmrossen Electrical 3 12-04-2011 10:07 PM
Installing Pool System New v. Used? flowerchick General DIY Discussions 5 10-27-2011 08:28 AM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 08:06 AM
