UV Light In Furance - HVAC - DIY Chatroom Home Improvement Forum
Old 10-12-2013, 06:38 AM   #1
Rewards Points: 93
UV light in furance
Hi all,
Last one ... We don't have any particular allergies or heath issues (at this time). We do have 2 cats. Sometimes they lay down some wicked stink bombs!.
I read that adding a UV light to the furnace return will help with bacteria and mold and some smells (I guess those from bacteria and mold).
There is a lot of discussion on the web about the effectiveness of these lights. The air is moving too quickly to be properly treated. The rush of air keeps the light cool (and therefore less effective). Only the line of sight air will be treated. Etc.
I have also seem some lights for as little as $100... and it goes up up up. There is one at Canadian Tire on sale now (reg $150 down to $100).
Any thoughts on these? If they are worth it, is there a real difference?
Cheers!
Terry
tls1 is offline   Reply With Quote
Old 10-12-2013, 09:46 AM   #2
An old Tradesmen
Rewards Points: 8,184
When properly placed above the indoor coil, they can be worth their money. But they should be the dual bulb type. So both sides of the coil are bathed in the light. However, some plastic drain pans age prematurely when exposed to UV light.
Old 10-12-2013, 10:46 AM   #3
Rewards Points: 93
so you are saying one needs 2 UV units. One before ac coils and one after. Are you implying it is only required during AC season?
What I really need is something to get rid of pet odors. Any suggestions?
Old 10-12-2013, 11:04 AM   #4
An old Tradesmen
The good UV lights are dual bulb units. So that when installed above the coil. It bathes both sides of the A of the A coil.
For odors. Just install activated carbon filters.
UV bulbs are often only good for 1 to 2 years. And can cost 50% of what the entire light did.
Old 10-12-2013, 11:27 AM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 396
If you want to get rid of odors install an HRV, heat recovery ventilator, Google Lifebreath or Venmar HRV. Those carbon filters are expensive and don't last very long in my experience.
Old 10-12-2013, 08:18 PM   #6
AKA HVACTECHFW
Rewards Points: 1,208
For odors I would tell you to look at RGF products.... I have had great luck in nursing homes with the guardian air.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Can blue (lightweight) drywall compound be used for all coats? amakarevic Drywall & Plaster 12 06-06-2013 10:41 AM
dimmer 'crossfade' when combining light circuits mitchl Electrical 8 12-11-2011 03:00 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
