Utility Room Sizing - HVAC - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 02:20 AM   #1
Utility Room Sizing
With a home that is built slab-on-grade, a 1st floor room will have to be used as the utility room to house the hot water tank, furnace, air handler, washer & dryer.
Currently it has been designed as sort of an "L" shaped room. The "L" portion of it is 21 square feet and the remainder is 19' long by 6' wide (114 sqft) for a total of 135 square feet.
Is this utility room sized good enough to fit all these items?
JackOfAllTrades is offline   Reply With Quote
Old 07-22-2012, 09:15 AM   #2
MarginallyQualified
Rewards Points: 2,464
E. Panel(30")/WtrHtr(30")/Sink+Wsh/Dry(84")/HVAC/Return(48") =192"x30"
Aisle space in front of all the equipment (door c/l at laundry) =192"x34"
Overall mechanical room space (192"x64") = 85 Square feet
Old 07-23-2012, 12:48 AM   #3
So with my 135 square feet, I should have decent room as your dimensions showed 85 square feet.
Adding a wall vent connected to utility room exhaust findlay70 HVAC 0 02-23-2012 11:29 AM
One room cold- what pipes are what...help cciampi HVAC 24 02-20-2011 11:44 AM
Freeze protection in utility room? akguy HVAC 1 11-20-2009 05:30 AM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 07:28 PM
Anyone know if it is code for a utility room floor drain? tigerbalm2424 General DIY Discussions 3 10-17-2007 10:48 AM
