Utica MGB125HID Not Working. - HVAC - DIY Chatroom Home Improvement Forum
Old 01-03-2010, 09:38 PM   #1
Angry
Utica MGB125HID not working.
Here it goes...Utica model MGB125HID Serial# CT04940 not working all the time. What I found out so far is this water on floor and what I believe is the honeywell gas valve (VR8204/8304) when opened manually alows the heater to work just fine but it does not work by itself. Currently -5 degress outside! Please help. Thanks J.
Last edited by AF4501; 01-07-2010 at 12:41 PM. Reason: Got it fixed. Look in last post, maybe help you!
AF4501 is offline   Reply With Quote
Old 01-03-2010, 09:54 PM   #2
Is the water on the floor from a plugged condensate line or something else leaked? Circuit board get wet?
Old 01-04-2010, 01:03 AM   #3
The water is just from the "overflow" valve and dripping only. pressure is good and temp is not to high eigther, when its running. board is a ok except for the valve that has honeywell stamped/embosed on it.
Old 01-06-2010, 07:02 PM   #4
Anyone have any idea about this problem?
Old 01-06-2010, 07:16 PM   #5
The only gas you should be able to produce manually from that valve is pilot gas. If you are getting main burner gas manually you need to replace that valve before it causes a hazardous situation. The leaking relief valve should not be leaking. What is the pressure in the system? If the system is low on water and you have a low water cut out you will have burner issues. Might be best to call a pro.
SKIP4661 is offline   Reply With Quote
Old 01-06-2010, 10:10 PM   #6
I mistook this valve. Its not a valve but it seems to be like a reset switch i.e. electrical. When kept open heater runs fine but the heater will not run properly on its own. I'm afaid this switch is a safety switch. The cause for the heater to turn off stay off is unknown. But that being said when kept open water pressure is good and water temp is good no safety problems there. Might be an electrical issue. I hope this will help J.
Old 01-07-2010, 12:40 PM   #7
Its all fixed now thanks for all the help! It turned out to be one of the zone valves was not working. Pro fixed it no problem. I hope this may help others, look to the zone valves first. Check them to see if any of the wires look burned. Again thanks everyone J.
central ac not working like it used to diyer1 HVAC 12 07-15-2009 03:30 AM
side by side light swithes not working katkell2645 Electrical 2 10-17-2008 08:22 PM
Inside Fan not working BenH HVAC 20 07-08-2008 07:10 AM
Working with granite... SDeeter19464 Remodeling 5 06-14-2008 06:51 AM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 02:47 PM
