Utica Boilers - HVAC - DIY Chatroom Home Improvement Forum
Old 12-31-2011, 05:22 AM   #1
utica boilers
purge light non indicator keeps going on , no heat
mejaydo is offline   Reply With Quote
Old 12-31-2011, 05:25 AM   #2
purge indicator light keeps going on, no heat. what to do.
Old 12-31-2011, 07:10 AM   #3
the Musigician
DangerMouse's Avatar
First off, keywords do not go over well here, this is not google, it is a DIY forum, populated with real people helping others. Patience is a virtue as well, since it will take a while for others to see your thread and respond. If you phrase your problem as a question, you'll get much faster help here.
We DO understand how having no heat can affect temperament and upset homeowners, especially if there are kids or elderly in the home. So please ask your question(s), add as many pertinent details as you can, (make and model #?) and someone will be along shortly to help if they can.
Just trying to help,
DM
Old 12-31-2011, 07:23 AM   #4
Sorry i'm new to this.
I have a Utica Boiler, model UB90-175, it is a gas hot water boiler, for heat only. The purge indicator light comes on and then i have no heat. The system will run for a short amount of time after i reset the power going to the boiler.
Old 12-31-2011, 10:54 AM   #5
JohnH1's Avatar
Here is step one.
Make sure the intake and exhaust vents are clear from any blockage. If there is a high snow drift blocking the vents it could cause this issue.
The below is from the manual. and here are some links. Hope it helps.
http://www.ecrinternational.com/secu...cument/338.pdf
http://www.ecrinternational.com/secu...ument/1565.pdf
BLOCKED FLUE/VENT SAFETY SHUTOFF
The Blocked Flue/Vent Safety Shutoff shuts off main burner gas in the event that the flow of combustion products
through the flue ways is reduced. In the event of blocked flue ways, enough air will not be available to support
combustion, and the Integrated Boiler Control (IBC) will lockout due to loss of proper airflow. The “PURGE” diagnostic
indicator lamp will blink indicating the failure mode as a lack of proper airflow. The IBC is reset from lockout by either
removing and reestablishing the thermostat’s call for heat , or by turning the service switch off then back on. If the
boiler cannot be restored to normal operating condition by resetting the control contact a qualified service agency to
check the flue ways for blockage.
JohnH1 is offline   Reply With Quote
Old 12-31-2011, 11:36 AM   #6
the Musigician
Not a problem, I'm glad to see you're getting assistance.
Please keep us posted as to your progress so future readers can benefit from your experience(s)!
...besides, we love a happy ending around here....
DM
Burnham vs Peerless Steam Boilers Jim11 HVAC 1 02-26-2010 11:54 PM
2 boilers thermostat wire installation... Handyman4u2fix HVAC 1 02-04-2010 01:50 AM
Peerless Steam Boilers BarbaraM HVAC 17 01-18-2010 08:55 PM
1 pipe Steam boilers BarbaraM HVAC 6 01-04-2010 06:13 AM
Buderus vs Utica guysr1 HVAC 0 09-21-2009 06:57 PM
